Glaron
Cape Cod, MA
Thanks for the reply guys ... and wise info.
Thanks OB ... will follow that course of action to the letter !!
Old-Biscuit
Across the USA
Glaron wrote: Thanks for the reply guys ... and wise info.
And if you do need a little drain cleaning action......dump some baking soda down into drain then pour some white vinegar in. After the bubbling action subsides follow it with very hot water. Cheap, simple and won't harm anything.
NRALIFR
Truck Camping Out West
What I do both at home and in the camper is to periodically flush the drains with a garden hose with a spray nozzle on the end. It helps push the stuff out of the P-traps that tends to accumulate there, especially under "low water usage" situations. At home, I hook the garden hose up to the drain valve on the water heater, which helps clean the drain out and flushes the WH tank out as well.
2001 Lance 1121, 1995 F350 7.3 PSD CC DRW with many mod's and upgrades (see profile page). Over 200,000 miles and still going strong!
sheldons65
Fort Worth, TX
Chris Bryant wrote: Drano produces a lot of heat when it works (an exothermic reaction),
Not the liquid.
I would use the geo method for routine cleaning.
Ka Ron
Kelowna
Try this one...
If you want to get your black water tank clean, the easiest and fastest way, here is what you do.
Buy three bags of ice cubes. Fill the tank half full of water and dump the ice cubes down the toilet into the tank. Drive your rig until the ice cubes melt. When you dump the tank the ice cubes will have scoured all the hard deposits from the tank and they will flush out down the drain.
doc brown
Redondo Beach, CA,
coolbreeze01 wrote: First time I've heard this theory. Think I'll pass.
Me to. I put some Pine Sol down periodically.
Steve,Kathy,Josh & Morpheus the Basenji
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2008 Wrangler X Rubicon/Blue OX Tow Bar/Ready Brake
Dave H M
IL
Far out
why try to fix something that is not broke.
cherrykiss3
edgerton ks
I just purchased a new 5er this past Nov. My manual specifically states NOT to use Draino or any product like it.
Cherry
ksg5000
Oregon
If you have pyramid issues you can always buy a quart bottle of septic tank cleaner - put in the contents - top off the tank with water - and come back in a 4 days or so and empty the tank - tank should be clean including the sensors.
Kevin
Dirtclods
Newport Beach
I use one of these and slide it down the toilet.http://fp.vendaria.com/vpop/VpopViewer.h........FFFFF&nm=BZOpener&err=0&title=&pf=t&fr=t
Take off the shower head and connect this http://www.homedepot.com/h_d1/N-5yc1v/R-........=-1&keyword=hose%20nazzles&storeId=10051
