Woodalls Open Roads Forum: My kid sprayed OFF (insect repellant) on plexi-glass door
 > My kid sprayed OFF (insect repellant) on plexi-glass door
Posted: 02/09/12 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Not worth the effort. Just replace it.
Burwoods
Outside Toronto, Canada
Posted: 02/09/12 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
yup replace
Bob and Sally
Kiwi_too
Western, WA
Posted: 02/09/12 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Replacement Part
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Davehrn
Ohio
Posted: 02/09/12 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
They make plastic polish for jeep windows it's a 2 or 3 step process.. check 4wd.com or summit racing... if you have scratches.. another trick is to use pledge furniture wax .. it fills in the small scratches works great but has to be reapplied every so often
~dave
2010 Coachmen Mirada 32ds
DW: Nora
DD: Silas White German Shepherd / Husky Mix
restorodder
Pinckney Michigan
Posted: 02/09/12 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
About 1990 I had a brand new Dodge van,that we were sleeping in,at race tracks. I sprayed Off all around the windows. In the morning I had streaks of blistered paint running down the side of the van. Cost the insurance over $1000. to repaint the side. It will remove paint,and we spray it on our skin?
2008 Newmar Canyon Star - 2007 Dodge Dakota Toad - Ready Brute tow bar & brake system - one cat - Sassy 14
ArchHoagland
Clovis, CA, USA
Posted: 02/09/12 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
I'm gonna try this stuff the next time I want to remove some paint.
I remember we used to use women's hairspray to remove printers ink off of mainframe computers 40 years ago.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse W22 Chassis
8.1 gas engine & Allison 1000 transmission
7.1 MPG based on fuel used over 46,000 miles
TOADS
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
1991 Mazda Miata 5 speed 33MPG 2,310 LBS
ryanallie1
Magalia, Calif
Posted: 02/10/12 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
Myself, I would try some "Awsome" from the Dollar Store. I have used "Awsome" on a lot of areas of our Motorhome. You don't really have to many options anyways. The worst case, is that you might have to replace the Slidder and the Stationary Peice. Its pretty cheap to replace, and only take a couple of minutes to replace it. I replaced ours,inless tyhan 5 minutes, becasue we didn't like the Black Slider and the Balck Stationary Peice, so we installed the Clear Set, so now nothing blocks our view our of our screen door now. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. HWH Levelers. 5.5G Gen. Convection/Microwave. 12 Cu Ft Side by Side. Water Purifier. Water Softner. 2 A/C's. Alarm Systems. 2 Honda EU2000i W/Kit. Toad CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68,& 70-71
flyswamper
Calgary, Alberta, Canada
Posted: 02/10/12 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Appreciate all the ideas on things to try. My wee bit of google-searching came across somebody who suggested using a mix of water, vinegar, dish soap to clean it up as well.
I'll definitely give some of these suggestions a try and I'll try to report back in this thread if I find something that worked. As pointed out already though, if all else fails guess we may just replace it whenever it bugs us enough to do so.
And, by all means, if there are other ideas out there let 'r rip with those too.
Constructive disagreement is encouraged. It is how I/we learn!
Dad,Mom, & 3 young'ns
Current Home (Calgary)
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 02/10/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Purple Power you can buy it at Walmart, not expensive, but a very good degreaser! Mask off any painted areas.
adondo
Pasco, Washington
Posted: 02/10/12 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
The best degreaser I've found and used is Greased Lightning. I've even cleaned the big Cat and its radiator in the coach with it. It also melts away that thick, sticky, kitchen grease buildup that Formula 409 and others won't even begin to touch.
But...
The Off! attacks the surface of plastics by etching it or semi-melting it. No cleaner on earth will fix that. It'll remove the Off!'s oily residue, but then you still have to buff out the damage or replace the item.
FMCA# F355513. 40 foot Safari Continental, one slide, Cat powered Magnum Blue Max chassis, PAC brake PRXB, Allison MD3060, Aqua-Hot, 7.5 KW Quiet Diesel, Howard PCS, Velvet Ride suspension. 2006 Jeep Commander.
