Woodalls Open Roads Forum: Toy Haulers: Voltage 3200 towing height
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers
 > Voltage 3200 towing height
jsdjr53
Austin, Tx.
Posted: 09/03/12 07:37pm Link  |  Print  |  Notify Moderator
Just bought a Voltage 3200 and I'm towing it with a 2012 F350 King Ranch 4x4. My problem is that my TH is about 4" high in the front when hooked up to my F350. I've already adjusted the hitch on th TV and air ride on the TH as much as can be adjusted. I'm now going to have the TH lifted 4" so I can get back to level.
I was wondering if anyone else with this TV and TH combination has run into this problem. The 2012 F350 4x4 (stock) towing this TH can't be that out of the ordinary.
My TH height will be 13'6". I'll be towing mainly in Texas, New Mexico and Colorado. Just wondering if anyone towing at this height in those states has run into any problems?
John
SouthernCamper74
Robbins, NC
Posted: 09/03/12 08:34pm Link  |  Print  |  Notify Moderator
Hey I've got a 2012 Voltage 3200 that I bought September 2011 and the truck is a 2012 F350 4x4 Lariat short bed with the 5th wheel prep package I bought this June. I don't really understand what your problem/question is. I have added a couple pictures below of my truck and camper and the Superglide slider hitch I use with OEM adaptor that fits the 5th wheel prep package in the truck bed. I'm not sure what my height is with my new truck, but camper sitting level without truck is approximately 13'4".
EDIT: Resized photo to fit the page.
* This post was edited 09/04/12 08:55am by an administrator/moderator *
Cherish every moment with your family like it will be you last!
2012 F350 Lariat Crewcab Shortbed, 20" Wheels, 6.7 Diesel
PullRite 15K SuperGlide System
2012 Dutchman Voltage V3200 Toy Hauler
2010 Yamaha 4X4 Rhino 700
2003 Honda Foreman 450
EZ-GO Golf Cart
joebedford
going to New Zealand instead
Posted: 09/03/12 08:53pm Link  |  Print  |  Notify Moderator
Those photos look pretty nose-high to me.
Is that hitch rated for a 3200? Sorry, I looked again and see that it's a 15K hitch. No wonder you tow level - your hitch is too small.
SouthernCamper74
Robbins, NC
Posted: 09/03/12 09:04pm Link  |  Print  |  Notify Moderator
Yes the adaptor works well with my slider and is very easy to take in and take out of the bed. The downfall is it raises the height of the camper up about 4" higher than the hitch sitting in the bed. I had to use this so my slider would work without buying a new hitch. But, if I ever do decide to go that direction it will be a B&W Companion OEM 5th Wheel Hitch. I haven't measured my camper height on level ground hooked up so I don't know what my height actually is. I don't travel long distances with the camper, not to say I won't, but just haven't at this point yet. Mainly because we are member's of a local private camp ground not to far from where I live.
* This post was edited 09/03/12 09:12pm by SouthernCamper74 *
stsmark
Northern CA
Posted: 09/03/12 09:41pm Link  |  Print  |  Notify Moderator
Are you using airbags or Timbrens? Is that how the truck sits stock with that pin weight?
Mark, Cathy and Zoey (aka The Golden Missle)
2011 F350 CCSB 6.7 (aka Frosty)
1993 Ski Nautique Closed Bow (aka Cal)
Lasher Sport ATH
Lasher Sport BTX
N-Trouble
NorCal
Posted: 09/04/12 05:44pm Link  |  Print  |  Notify Moderator
From the first photo it is pretty obvious you are also nose high just like the O.P. maybe even more so. THe only real way to correct this is to flip the axles on the trailer. Newer 4x4 trucks sit higher stock than they did a few years back and I don't think the trailer manufacturers have gotten the memo.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
720Deere
Maryland
Posted: 09/04/12 06:18pm Link  |  Print  |  Notify Moderator
Their website lists the 3200 pin weight at 2361 which seems extremely light for a trailer that size, but judging from how the truck is sitting with the load compared to how mine sits with around 1800 lbs, I would say it is close.
2011 Ford F-350 4X4 CC LB SRW 6.7
2013 Keystone Fuzion 315
B&W Companion Hitch
1 wife 2 kids and 1 dog
lightfoot
Cary, Illinois
Posted: 09/05/12 07:52am Link  |  Print  |  Notify Moderator
I think the OP might have some additional suspension on the truck. I have a 2012 F250 6.7L 4x4 LB SC and when my V3200 is attached everything is level. I don't have the actual weights at this time, they are at home somewhere, but if I can get a picture of the setup I will post it later. My hitch is a Q20K and I have 10K axles on the TV.
USN EN2 (RET)
2012 Ford F250 SC, 6.7L Turbo Diesel
2015 Voltage 3200
2004 Honda GL1800
RCMAN46
NorthWest
Posted: 09/05/12 10:13am Link  |  Print  |  Notify Moderator
Watch your overall height. Most states have a limit of 13' 6 " and Colorado has a 13' limit.
Now we will be told by others they have a trailer taller than that and never have had a problem. But I suspect if you damage an overpass in a state that has a limit below your trailer height you may be liable for damage to the overpass and possibly your Insurance will not cover your loss to your trailer.
Just something to consider.
1Wheeldrive
The Rockies
Posted: 09/05/12 11:09am Link  |  Print  |  Notify Moderator
I have a 2012 Voltage 3200, tow with a 2003 Silvarado 2500 HD. Scaled pin weight is 2700 lbs (they are always heavier than the brochure or website says they are). I have air bags that brought the truck up to level, and the trailer tows level, B&W turn over ball with 5th whell companion hitch. My trailer is about 13' 4" tall, and maybe I've missed something, but I have never heard about or seen a height restriction on an RV other than the signs posted at bridges and tunnel entrances. Most 18 wheeler boxes are 14' tall.
I do know that I can't get into Chatfield State Park from the west side, the entrance kiosk is about 12'6".
