BigSur2
Hampton, VA
A very close neighbor of mine that had done TON of work for me over the years just bought a new TT. He wants me to pick it up for him b/c he doesn't have his truck ready to pull yet. TT is about 4.5k lbs gross....tongue weight around 450 lbs. I'd have to pull it about 30 miles of highway with NO WDH. If I take my time, is that okay.....or am I just asking to wear my shocks out.
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
Ron3rd
Upland, CA USA
I would do it. 450 tongue wt is not that much IMO. This assumes you can take your time. It won't hurt your shocks in any event.
2007 Tundra SR5 CrewMax 5.7 V8
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Raymon
Phoenixville, PA
Another issue you may want to consider is what is your liability if something goes wrong and the TT is damaged? Sometimes bad episodes can ruin friendships very quickly. I am just guessing, but when the TT is hooked to your pickup, your insurance may be liable for any damage to the TT during towing. If your friend pays you to tow the TT, then the insurance issue just get more complicated.
It is always nice to try to help a friend, but just be careful you have all your bases covered.
Ray
Sidney911
Ohio
You didn't say what vehicle you are towing with. Your shocks shouldn't be a problem. The big worry is if you can stop and steer. With less weight on the front end, steering and braking should be a concern. But if you take your time, be cautious, you should be ok.
Sid
Helmsey
Knoxville, TN
You should not have any issues. Sounds like a good opportunity to help out your helpful neighbor.
KK4PFX
2010 Chaparral 322RLTS
2004 Chevrolet 2500HD D/A CCSB 4x4
Days camped in 2011: 22
Days camped in 2012: 34
Days camped in 2013: 6
JRS & B
Florida/Michigan
What is the tongue weight of your current trailer? Is it not greater than 450 pounds? You will have the trailer brakes connected, won't you? I would not be worried about wearing out the shocks in that short of a distance.
swebber
Brunswick , MD
Helmsey wrote: You should not have any issues. Sounds like a good opportunity to help out your helpful neighbor.
X2 I would have him ride along to make sure that all is good and that there is no blame game should there be a problem.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
mowermech
Billings, MT
Go get the trailer, but allow your friend to do the driving in your truck.
Your insurance should cover him, and his insurance should also give some coverage.
Chances are, nothing will happen, but in the unlikely event that something does, HE was the driver!
CM1, USN (RET)
2002 Fleetwood Southwind 32V, Ford V10
Toad: 2006 Jeep Rubicon LJ
Other toad: '06 PT Cruiser, Kar Kaddy dolly
Toy: 1977 Dodge W100 CC SWB, 3/4 ton axles & springs
five'er
Canada
I assume you have WD on your trailer? Is it the chain type? My WD is clamped onto the Trailer frame.. A couple turns with a wrench and I can have it off and on another in no time at all. Yours may not be the same.
Queens Carriage
Treasure Coast, FLorida
x2 to mowermech
