sellstroms
Greensboro, NC
Last week we spent 6 days at a campground without sewer hookup. I decided to try two tips I had read on this forum and am happy to report success in both areas.
1. No toilet paper into the tank. We put all used toilet paper into a bag (which we threw out each night!!)
2. Poured used dishwater into the toilet each time I finished doing
the dishes.
The dumping process was quick and easy. Somehow the dumping chore has fallen to me, and I appreciate any tips that make it easier. Thanks to whoever posted those tips!!
Keep the ideas coming!!
pianotuna
Regina, SK, Canada
Take a sheet of toilet paper and put it in a glass of water. Wait a day and see what is left.
Dumping dish water into the black tank is more about saving capacity in the grey water tank than increasing the effectiveness of the black water tank.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
jetboater454
Camping or home
Can't see toilet paper taking up that much room in the tank.
"If momma not happy ....Who cares.I have my TH AND my toys .
2008 3500 Dodge Ram CTD dually 4X4
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
rsmith159
Cobourg
Well, I'm glad these ideas worked out for you but if I had to put used TP into a bag to get through a camping trip I would 1)Stay home 2)find another campground with sewer hookup 3) use campground toilets 4)shorten my trip. Other options may come to mind later. What about pump out services? I think sometimes things are taken to extremes. Camping should be enjoyed, not tolerated.
Rick in Cobourg
2008 Trail Lite Crossover 180T
2010 Ram 2WD Hemi
Billieg2
Gone from this forum
pianotuna wrote: Hi,
2X. The paper won't make a big difference. The dishwater will help with cleaning your sensors but usually the grey tank is bigger than the black and if worse comes to worse you can let a little grey water out without any harm on the ground. Many cities use grey water to water lawns.
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
donn0128
Pronounced Ore-gun
Personally I see neither of those ideas as worth a hoot. The black tank is for holding humane waste. There are all sorts of enzymes in there that help break down the solid matter. Dumping dish water in there basically kills those good things. Using a septic safe toilet paper is all you need and it too goes down the toilet. Get yourself a blue boy, or what ever you call it in your area and carry it along with you on those times when there is no full Hookups. Most campgrounds will have some sort of teepee for dumping gray water. With correct use the black tank should last for nearly a week for two to three people.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
johnwalkerpa1
Pennsylvania
sellstroms wrote: Last week we spent 6 days at a campground without sewer hookup. I decided to try two tips I had read on this forum and am happy to report success in both areas.
the dishes.
Well....Item 2 I sometimes do if I need to save gray tank space, but no thanks on item 1!!!! I've never needed to save black tank space that bad.....
rr2254545
Minnesota/New Mexico
jetboater454 wrote: Can't see toilet paper taking up that much room in the tank.
Agree - yuck on not putting it in the tank - wow who even thought that one up
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
rockhillmanor
On the Road
I agree. DO put your tp paper IN the toilet. Just make sure since you do not have hookups that you buy the RV toilet paper. Not as nice to use but it DOES break down rapidly.
I am at a CG right now that does not have hookups. They come around once a week and pump your black tank. They insist that you let the gray water go into the ground. Ask your CG host. You might find out that they do allow you do dump gray out on ground.
.....goes IN the toilet!
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
WoodGlue
Los Angeles / Montana
Just as a FYI, COSTCO KIRKLAND toilet paper is fine for an RV toilet. It's a lot more affordable too!
Don't believe me? Take a few sheets, put it in a jar with some water and give it a few shakes and you'll see what I'm saying! Then try this with a Kleenex tissue then maybe some Quilted Northern or Scott Tissue. You'll get it!
2002 Land Rover Discovery II
2013 LANCE 1685 Travel Trailer - Video Tour - Video Tour 2
Lance Uses Azdel - Why It's Better Than Wood In Your RV Walls
There Are 84 Less Chances Of A Roof Leak In A Lance
Lance Factory Tour
2014 LANCE 1685 On Order! Yay!
