Woodalls Open Roads Forum: General RVing Issues: WA State Chain Requirement
 > WA State Chain Requirement
Page of 7
mockturtle
WA
Posted: 11/01/12 08:30am Link  |  Quote  |  Print  |  Notify Moderator
The WSDOT has issued the following requirement for vehicles over 10K lbs. GVW. Be aware that, according to transportation officials, this law applies regardless of weather conditions.
WSDOT Chain Requirement
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
ScottG
Bothell Wa.
Posted: 11/01/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
The only time you would have a problem is if you got stuck or the conditions were so bad that you really needed chains and couldn't produce them. They don't just randomly pull folks over and check to make sure your carrying them.
Scott, Grace and Wesly
H0NDA eu2000i
enblethen
Moses Lake, WA
Posted: 11/01/12 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the toad has to have tire chains for the last braking axle.
Heard that the troopers are planning on doing some traffic metering on some passes. Plan is to do it similar to Oregon, by checking for chains.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
n7bsn
Yes
Posted: 11/01/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Per a WS-DOT spokesman on KOMO yesterday, they plan to do an emphasis patrol on the passes sometime this month and do exactly that, pull over random large (10K lbs) vehicles and check for chains, ticketing every one that doesn't have them.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
rhagfo
Portland, OR
Posted: 11/01/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
So I carry one set each for the truck and trailer, looks like I may need to step up to two sets for the truck. You should still be legal with one set for the trailer.
Looks like time to by a set of cables for the truck and trailer, already have real chain chains for the truck.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
enblethen
Moses Lake, WA
Posted: 11/01/12 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I would get them from Les Schwab so you can retunrn them in the spring or when ever.
Might check at some of the second hand stores. I got a set for daughters' car for $10 a set. Both have four wheel drive. You must carry chains in four wheel drive
Like most, I will probably never install them.
Cummins12V98
on the road
Can you say revenue enhancement program???????
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
belfert
Shoreview, MN, USA
Posted: 11/01/12 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Does this apply in the summer too? If so, I can scratch Washington state off the list of places I will take my motorhome.
I'm not going to spend hundreds of dollars on a set of chains I will never use. I have never, ever seen any vehicles with chains on in Minnesota where I live. I also don't drive my motorhome in the winter.
2oldman
Winchester WA
Posted: 11/01/12 11:13am Link  |  Quote  |  Print  |  Notify Moderator
"all vehicles and combinations of vehicles over 10,000 pounds shall carry sufficient tire chains to meet the requirements from November 1 to April 1 of each year or at other times when chains are required for such vehicles"
No, unless snow is imminent in July.
mowermech
Billings, MT
Posted: 11/01/12 11:20am Link  |  Quote  |  Print  |  Notify Moderator
"On the following routes all vehicles and combinations of vehicles over 10,000 pounds shall carry sufficient tire chains to meet the requirements from November 1 to April 1 of each year or at other times when chains are required for such vehicles:
I-90 between North Bend (MP 32) and Ellensburg (MP 101)
I-82 between Ellensburg Exit 3 (MP 3.00) and Selah Exit 26 (MP 26.00)
SR-97 between (MP 145) and Junction
SR-2 SR-2 between Dryden (MP 108) and Index (MP 36)
SR-12 between Packwood (MP 135) and Naches (MP 187)
SR-97 between junction SR-14 (MP 4) Columbia River and Toppenish (MP 59)
SR-410 from Enumclaw to Naches
SR-20 between Tonasket (MP 262) and Kettle Falls (MP 342)
SR-155 between Omak (MP 79) and Nespelem (MP 45)
SR-970 between (MP 0) and (MP 10)
SR-14 (MP 18) to Junction 97 (MP 102)
SR-542 Mt Baker Highway between (MP 22.91) and (MP 57.26)
So, not only is it time limited, it is ROUTE limited. It applies ONLY to the routes annotated.
Worthy of note also is that the regulation is contained in the COMMERCIAL statutes, and thus may not apply to Recreational Vehicles.
Then again, why anybody would want to take a motorhome over one of those passes when the CHAINS REQUIRED signs are posted is beyond my comprehension!
But, that's just my opinion...
CM1, USN (RET)
2002 Fleetwood Southwind 32V, Ford V10
Toad: 2006 Jeep Rubicon LJ
Other toad: '06 PT Cruiser, Kar Kaddy dolly
Toy: 1977 Dodge W100 CC SWB, 3/4 ton axles & springs
Page of 7
