JRS & B
Florida/Michigan
Our four year old Garmin costs about $250 at Sam's Club. It cannot seem to acquire a satellite. It still thinks we are in Monroe Michigan, 1200 miles away. The screen and buttons work but the only thing it seems to know how to do is tell time.
Are these things fixable or should I just junk it?
TURK2500
SE Michigan
Depends on the model, some of them can be repaired (software upgrade, etc.). I would contact Garmin because it may be a known issue.
Bob
02 Chevy, 2500HD/4x4, 6.0L/4:10, GVWR 9,200lbs., GCWR 16,000lbs.
05 Jayco Eagle, 278FBS, GVWR 9,000lbs.
TV/TT loaded: 14,700lbs.
Loaded Tongue Weight: 1,250lbs.
Loaded TT weight: 8,400
Putnam XDR Class V, Reese HP Dual Cam.
dspencer
Missouri
I had the same problem on mine which at the time was only a year old. It just needed a software update, can't hurt too check and see.
JRS & B
Florida/Michigan
For what it's worth, the model number on the bottom is nuvi 1350
JRS & B
Florida/Michigan
dspencer - I hate to display my stupidity to the world, but how did you upgrade the software. Did you send in the unit, or is there something that can be downloaded?
TURK2500
SE Michigan
Found this at the Garmin site: Nuvi 1350 Updates
Bob
donn0128
Pronounced Ore-gun
Connect it to a high speed Internet computer and download any and all updates. But without the proper patch cord you will be dead. Do you have it?
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
JRS & B
Florida/Michigan
I will have to pick one up.
It seems to look like a miniature USB port.
So a regular USB plug on one end for the computer, and a smaller/thinner one on the other end for the Garmin.
Fred_n_Jo
central MO, USA
Here is what you need.
https://buy.garmin.com/shop/shop.do?pID=1345&ra=true
2011 HH DA 349 RSB 5th
2011 F350 Lariat 6.7L PSD CC SB 4X4
18K PullRite SuperGlide & 50 gal Titan fuel tank
our places camped Map
bikendan
Napa, Cal.
JRS & B wrote: I will have to pick one up.
the cable comes with the GPS, when you buy it. did you buy it second-hand?
the instruction manual shows how to update the software.
the manual can be downloaded on Garmin's website.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
