Woodalls Open Roads Forum: General RVing Issues: How to simplify travels
 > How to simplify travels
PcolaCamper
Pensacola FL
Posted: 11/21/12 03:05pm Link  |  Print  |  Notify Moderator
I would love to hear ideas from all my fellow campers for ways to minimize physical exertion during set up, overnighting, and all things camping in general. My DH has a bad back and he is in pain, and we are both exhausted when we get back from a trip. We mostly go on weekends right now but planning longer trips soon. I was thinking about suggestions such as leaving the TT hitched up during overnight stays, don't extend awning, maybe we could forgo the stabilizer jacks for one nighters. We are planning a trip to Yellowstone this Spring/Summer, we need to be able to "go the distance". BTW, I'm retiring soon!! I'm so excited!
MTPockets1
USA - Usually West
Posted: 11/21/12 03:11pm Link  |  Print  |  Notify Moderator
We try to have as much electric as possible.... If your stabilizers are manual crank, use an electric drill instead. Electric is also avail for the tongue jack. Awnings too, and power cord reel. Use quick disconnects on water hose. Just go slow and enjoy. Can't recall the name, but there is a swing out boom for the dump line, or get an extension to reduce bending and reaching.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
K Charles
Connecticut
Posted: 11/21/12 03:13pm Link  |  Print  |  Notify Moderator
Electric stabilizers, don't unhooked for an overnight and sometimes it takes us 4 days to drive a 2 day trip. Stay a couple nights when traveling, what's your hurry.
Triker33
Homestead, FL
Posted: 11/21/12 03:16pm Link  |  Print  |  Notify Moderator
Trade the TT for a Class C or A with auto jacks.
Carry some water in the fresh tank and for overnights you only have to hook up the electric.
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
Posted: 11/21/12 03:18pm Link  |  Print  |  Notify Moderator
The best thing we ever got was the electric tongue jack. Purchased it on ebay from Mantelli Sales for about $150. Wonderful thing.
We have a drill with a socket attached specifically for the stabilizers. It stays in the front storage compartment, plugged in. (We did have to run power there).
If we are only staying a couple of days and especially if the weather is supposed to be good, we don't extend the awning.
We have an outdoor kitchen that we only set up if we are going to be in one spot for several days (5+) - it's just too much of a hassle.
DH also has a bad back, so I usually do most of the outside setup and most of the inside setup is done at home before we leave. I put down the jacks, connect the power, water and cable. He usually handles the tongue jack and unhooking it from the truck.
If I have a problem, he will help me, but the same goes for me.
rockhillmanor
On the Road
Posted: 11/21/12 03:27pm Link  |  Print  |  Notify Moderator
When I had my TT I often ran into the same discomfort. And soon the trips where not being a lot of fun.
First of all 'absolutely' leave the TT attached when staying just for the night or even two. Simply ask for a 'pull thru site' at the CG you choose. EVERYONE does that! [emoticon]
I travel with dogs so the transferring of all of them from the truck and reversing the process became a 'real' pain.
Sorry I can't offer you more tips because between the hooking and unhooking, etc. and the many times having to be on all the time pulling a trailer in inclement weather that left me pretty exhausted also.
I sold the TT and bought a MH. I can't tell you that for 'me' how much MORE pleasant RV'ing is in a MH. Pull in, put it in park, and open a cold one, and sit and watch the others spend an hour setting up. [emoticon][emoticon]
Good luck and congrats on your upcoming retirement!
HappyKayakers
Malabar FL
Posted: 11/21/12 03:46pm Link  |  Print  |  Notify Moderator
X2. If the bad back is not going away you might as well get rid of the TT before it gets worse.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/
navegator
San Diego CA.
Posted: 11/21/12 03:55pm Link  |  Print  |  Notify Moderator
We try to get a pull through when possible for an overnight we pull a small toad behind and do not disconnect, only take key out of ignition and lock.
We only hook the electric cord, I am going to get the new yellow connectors that have a handle to pull the plug out at the pedestall.
We do not use the jacks if the rig is fairlly level if not I only lower the jack that is needed to level.
We also carry a full tank of water, it helps distribute the weight font to back, my C is rear end heavy.
We do not extend the awning, or any thing else for that matter, the less work the better.
My jacks are manual and I use a cordless drill to lower and raise them, then the jack handle.
My wife now is comfy with the rock and roll, me I sleep through a hurricane in a small ship.
navegator
PcolaCamper
Pensacola FL
Posted: 11/21/12 04:14pm Link  |  Print  |  Notify Moderator
Thanks for your replies. We already have the electric tongue jack and use a drill to lower the stabilizers. We plan to take it slow and enjoy the drive. As far as trading for a class C or A, that isn't an option for us due to finances, especially due to upcoming retirement, though I would love it. I had not heard about an extension for the dump line, may need to check on that. We decided on the TT so we can have the truck for everyday use. Don't plan to get rid of it soon, I think we can handle it awhile yet.
donn0128
Pronounced Ore-gun
Posted: 11/21/12 04:34pm Link  |  Print  |  Notify Moderator
Talk to your doctor about getting a tens unit. It will not make things easier, but it will help relieve the back pain.
The Other Dallas
Over 1,200 volunteer hours
