Aurabbit79er
South Bay Area, Ca.
I have already removed the propane system.
Added 2 more batteries. Started putting solar panels on the roof.
I'm building a removable VAWT (vertical axis wind turbine).
I never had a gas generator.
Now I don't think I'll need one.
I like to boondock so I want to make the coach more independent.
I would appreciate any thoughts.
In all the advancing we can do to improve this world, the sharing of knowledge and wisdom is the most important.
If I post anything that inspires anyone, I did my part.
And If anyone inspires me to try to do better, I thank them now.
2oldman
Winchester WA
An electric refridge is going to be a challenge in cloudy weather.
Of course all this is highly dependent on your consumption. I have 800w of solar and I still find I do need a bit of generator from time to time.
Dakzuki
Carnation, Wa, USA
Staying warm will be a challenge in cool weather.
If I was going to go without LP I'd get a diesel RV and use diesel fired stuff like Earthroamer does.
2011 Itasca Navion 24J
95 Chinook Premier
RVUSA
Orlando, FL, USA
details on the vawt please.
Artum Snowbird
Campbell River, B.C., Canada
The beauty of propane is it provides heat while your batteries circulate it. But, with what you are in, perhaps you have a non-electric furnace and a non-electric fridge too.
In that case, it just might work. Here's hoping for sun.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
pnichols
Santa Cruz Mountains
How are you going to stay warm with no propane? How are you going to cook with no propane.
In my opinion propane or diesel appliances, and a generator, are things you add for good non-hookup camping - not take away. You can go only so far/long with only pure solar and/or wind and big batteries. A source of much higher density energy storage and delivery - as is made possible via propane or diesel fuel - is necessary for extended non-hookup camping to keep from freezing or eating heated food.
Phil, 2005 E450 Itasca 324V Spirit
Aurabbit79er
South Bay Area, Ca.
2oldman- I have been using conservative power methods and spend most of my time in the wilds I visit then return to the Coach. So I charge during the day and use at night. Watch a movie, listen to some music.I cook with a butane single burner portable. Any propane I use is also portable. I have a old small 24" class C w/a Chevy truck cab. A 79 Roll-A-Long. Not much to look at now. It's my project.
Dakzuki- I am having a little Refer madness. I think the technology is catching up with low power usage combined with High insulation.
When I win the lottery That Earthroamer is top of the list.
RVUSA- The 16 COIL Stator and the Neodymium weather proof rotor, will be mounted permanently on the roof with a Strong Vertical shaft. The turbine(or Squirrel Cage)will set on the rotor and twist lock on to it. I'm looking at a 2'dia x 3' tall and will produce 60 watts@12VDC. At least that is the plan.
ktmrfs
Portland, Oregon
Aurabbit79er wrote: I have already removed the propane system.
It's hard to beat propane on an energy density/lb or energy density/cu ft. I'd still keep propane for stove, WH, heater and fridge. The things that are big energy consumers.
I'd personally have a hard time living w/o propane.
2011 Keystone Outback 295RE
2004 14' bikehauler with full living quarters
2004.5 Silverado 4x4 CC/SB Duramax/Allison
pianotuna
Regina, SK, Canada
How much solar do you plan on installing?
I'm most interested in the VAWT technology.
What size is the battery bank to be? What chemistry?
Have you considered an inductive "hot plate"?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Aurabbit79er
South Bay Area, Ca.
Artum Snowbird wrote: The beauty of propane is it provides heat while your batteries circulate it. But, with what you are in, perhaps you have a non-electric furnace and a non-electric fridge too.
The free energy draw has a hold on me and this Coach is like a empty canvas. I want to make it mine. I had to put a new ceiling beam in when I first bought. The AC unit was falling in. From that point on I knew I was remodelimg.
