Woodalls Open Roads Forum: General RVing Issues: Tire shred
 > Tire shred
calewjohnson
Florida
Posted: 01/11/13 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Welll, it happened to me a couple days ago. Driving up I-95, just south of the VA state line... There was a shudder and a violent vibration. Pulled over and did a walk around, my right rear trailer tire had no tread, still inflated though. I took some pictures, drove to the next exit and changed the tire. There is cross member damage, wheel well damage, and inside floor damage. Filed with Progressive, they are taking the tire and talking to the tire company...they said that these failures are increasing in numbers. My tire was a 205 75R 14, MAXXIS. I am anal about my 50psi and I very rarely go beyond 65mph. This happened in the early morning and cruise was on 60.
I am looking at some Loadstar tires, same size, but loadrange D. Any thoughts? The boat pulling guys seem to bee happy with them.... I took the tire off the rim expecting to see a max psi stamped on the I side, only see a Made in the USA, rim size, and the date. Any idea where I shod look next? If I go up to loadrange D, I will need to inflate to 65....
Thanks,
Cale
2005 Chevrolet Silverado 2500HD, 4x4, D/A
2007 Fleetwood Nitrous 23ft Toy Hauler
I am still wayne_tw
everywhere
Posted: 01/11/13 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
First, you should take your RV, a toyhauler I believe, to the scales and weigh it loaded like you use it. That may surprise you and change your tire shopping direction!
donn0128
Pronounced Ore-gun
Posted: 01/11/13 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
You answered your own question. Rarely over 65 even once is enough to start the problem
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Passin Thru
N VA
Posted: 01/11/13 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
We had Good year Marathon and they blowout the side wall. Our dealer said he did'nt even sell them anymore, said to buy Michelin LTs with a D load rating from Costco, he also recommended anti sway bar on the rear axle, will take the load off the tires by cutting down the ammount it moves sideways. He's a good guy and I take him other work.
calewjohnson
Florida
Posted: 01/11/13 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Ummm...not helpful. I did not answer my question. Read it again. Going 70 is fine for the tires, 65 is not the edge of the cliff, there is an engineering safety factor figured in...
First part of post was general info, second part is question. Try again Bud.
Cale
Passin Thru
N VA
Posted: 01/11/13 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
BTW/Asked him about the speed and he said a properly inflated tire was built for Road speeds meaning 70 or 75 even, however, All ST tires are built for 65 or under, thats why he said Michelins.
Passin Thru
N VA
Posted: 01/11/13 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
http://en.wikipedia.org/wiki/Tire Read up on it. Pressure Max is required to be stamped on the side of a tire so it's on the other 3.
calewjohnson
Florida
Posted: 01/11/13 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
2 reasons not to go over 65...1st, the tire, 2nd...my mpg goes down the toilet. I have found that GPS 63mpg gives me 12.8mpg (pulling 7000lbs).
My TH has minimal clearance in the wheel wells. Anything more than a 14inch and I will be banging the wheel wells.
Cale
calewjohnson
Florida
Posted: 01/11/13 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I know the max psi for the tires, it is the rim.... I don't want my rim to come apart...
Old-Biscuit
Across the USA
Posted: 01/11/13 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
May not be a MAX PSI on rim...might only be a MAX Load
If not stamped inside on the valley then should be stamped on side of rim.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
 > Tire shred
