nohurry
Orting, Wa
I just read Mello Mike's trip report on Quartzite Az, which was excellent. As I was reading about his shopping at the big RV expo he mentioned that he bought new locks for his storage compartment to replace the common type that a lot of RV's have and not only can the key open many other RV's storages, but the lock itself isn't all that strong. That's when I realized that the front pass-thru storage on our new Jayco is accessable fom the inside just by lifting the bed! Are you making the conection here? Why bother with the latch, and deadbolt on the doors if all a ner-do-well has to do is pop the storage door crawl in, push the bed up and presto...he's in your rig!
The locks that Mike ordered are on industrial lock and hardware's website. Look for the tag "attention RVers". They will set you up with a stronger tubular type lock that has your own key code. I plan on ordering three of these for my storage doors right away. I think I'll also put a cover over the pass-through portion of the under bed storage.
This may have been brought up before, but I just thought I'd give a heads up to a problem others may not have noticed before.
Carl
03 F-150, 5.4 Scab 4x4 auto 3:55
2011 Jayco 256RKS
Co-pilot-Sharon
Navigator-Missy (chihuahua)
JJBIRISH
Butler, PA, USA
Not only brought up before but I thought it was the best know secret about RV’s…
These things are not very secure and won’t be with better baggage locks…
I can open almost any baggage door or entry door without a key if I want to with just simple tools…
And my entry keys will fit a half dozen different entry doors around me at the home base…
Now that’s security…
downtheroad
Pacific Northwest
Changing the locks is all well and good...but any of these compartment doors can be easily pried open with a simple screw driver - regardless of how stout the lock is.
Kind of like locking a cardboard box...
edited 01/15/13 02:14pm by downtheroad *
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
LadyRVer
Florida
I had a unit and a part of the flooring with carpet would lift up (access through the storage bay) to put a laundry basket in. I figured out a way to secure that part of the flooring and there was no getting into the RV through the storage compartment up into the inside.
fatmanobx
Russellville, Ar. Home Base
Just install a slide bolt on the bed platform and that will take care of that concern..but as mentioned, if someone wants in, they are going to get in.....
2003 Four Winds Infinity 37'
2011 Lance 855
3.5# Minpin named Darcy
Ford F250 Super Duty
Triker33
Homestead, FL
Waste of money and time putting different locks on.
If someone wants in different key locks won't stop them.
In 13 years of full time my compartment have been only locked one time, that was while the MH was in a body shop.
Nothing stolen yet.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
Banks Powerpack
DataStorm SatMax5 | VMSpc | Pressure Pro
08 HHR LT2
Click here to see where I am
mowermech
Billings, MT
So, you spend many dollars for high security super strong locks with "special key codes", then install them on doors that are barely stronger than double thick corrugated cardboard.
Somehow, the logic escapes me...
CM1, USN (RET)
2002 Fleetwood Southwind 32V, Ford V10
Toad: 2006 Jeep Rubicon LJ
Other toad: '06 PT Cruiser, Kar Kaddy dolly
Toy: 1977 Dodge W100 CC SWB, 3/4 ton axles & springs
2oldman
Winchester WA
mowermech wrote: spend many dollars for high security super strong locks with "special key codes", then install them on doors that are barely stronger than double thick corrugated cardboard.
Somehow, the logic escapes me... Yah, I gotta agree with this. Rv are just too easy to break into.
Pangaea Ron
Anacortes, WA, USA
When I bought my Class C from a rental facility in Canada, they had to erect chain link fencing around their yard. It seems that local homeless people were entering MH's through the rear storage compartment, and lifting the bed for a great night's sleep. The locks were not enough.
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
shooted
Vancouver
Lost my keys last summer for a couple days and the spare keys were of course locked in the trailer. I was able to get into the trailer without damage in five minutes with nothing but a screwdriver.
Sometype of audio alarm may actually be more effective depending on circumstances.
