Woodalls Open Roads Forum: General RVing Issues: 800 watt harbor freight genny coupon
 > 800 watt harbor freight genny coupon
RV daytrader
PA
Posted: 01/21/13 12:28pm Link  |  Print  |  Notify Moderator
harbor freight 800 watt genny usually on sale for 99.99 with coupon...found a coupon in a magazine for 89.99...going to pick one up...coupon code is 15716895 for anyone interested
YODA...our lil Toyota!
1989 Toyota Seabreeze
K Charles
Connecticut
Posted: 01/21/13 12:50pm Link  |  Print  |  Notify Moderator
I can hear it from here, runs good.
MWJones
Posted: 01/21/13 01:08pm Link  |  Print  |  Notify Moderator
What do you plan on running off a 800watt genny, a couple of light bulbs???
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
beemerphile1
Ohio
Posted: 01/21/13 01:09pm Link  |  Print  |  Notify Moderator
You will like that generator. They are not as loud as people claim. I got mine for $73 a couple years ago.
The extended warranty is a good investment. The first generator went back because it was defective. Second one runs like a champ.
MWJones, my HF 800/900 will operate the converter to charge the batteries, it runs the microwave, it runs a 5,000 BTU air conditioner, electric chain saw, and other things.
2016 Silverado 3500HD DRW D/A 4x4
2006 Weekend Warrior FK1900
Gale Hawkins
Murray, KY
Posted: 01/21/13 01:33pm Link  |  Print  |  Notify Moderator
2x
Our HF 800 gets started more often than any of our generators because it is so handy. At sub $100 it is a good option we have found.
tvman44
Southwest Louisiana
Posted: 01/21/13 02:05pm Link  |  Print  |  Notify Moderator
Been thinking about one to run a fan outside when no electricity is available.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
K3WE
Missouri
Posted: 01/21/13 02:19pm Link  |  Print  |  Notify Moderator
For cool weather, it might run the whole trailer and charge the heck out of the battery. Probably have to shut some stuff off before running the microwave.
And to do arithmatic- at least 13 60 watt bulbs if they wanted to.
RV daytrader
PA
Posted: 01/21/13 02:25pm Link  |  Print  |  Notify Moderator
Nice to hear good things from folks who ACTUALLY have one...just ignore the smart arse remarks from those who DON"T!!!
Gale Hawkins
Murray, KY
Posted: 01/21/13 02:59pm Link  |  Print  |  Notify Moderator
It is not cheap but we did the 25 hour break in per the manual and I think that paid off.
I would like to have a Honda but they have longer legs and can walk off farther. [emoticon]
We have a 6 amp manual charger we use with the HF 800 genset that we are OK with using to charge a battery at a remote site and leave running risking it getting stolen. The 5 hour run time with that light load is enough to start most engines if the battery is just low. Running work lights is a good task for the generator.
The output is not as smooth/clean as an inverter type. When I was using the HF800 to charge the 36v golf cart I noted the EZGO computerized charger output needle was bouncing some so I stopped using it since that charger is around $400+ new. [emoticon] I will in the future test it again with the HF heat gun also running on the 200 watt setting to see if that helps stabilize the output because I have noticed the engine is more stable under a 600+ watt load.
ecoast
NW NJ's Highlands
Posted: 01/21/13 03:03pm Link  |  Print  |  Notify Moderator
I have used mine to light 2 500w work lights; no problem!
when Sandy came thru it ran my full size ge fridge as well as a lamp and all the device chargers/laptop power supplies...
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
