Woodalls Open Roads Forum: General RVing Issues: Heating Bed
 > Heating Bed
bazdad
Pensacola Florida
Posted: 01/24/13 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I am tired of the cold bed in the 5er when getting to a camp site after towing. The bed is a queen with a 2 inch memory foam. I need some input whether a heated mattress pad or a electric blanket. I am an old man with lot's of blood thinner and get cold at night. I appreciate some help with this decision.
2oldman
Winchester WA
Posted: 01/24/13 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Mattress heater. I'm assuming you're plugged in, cause if not you'll need a good psw inverter.
Pepperoni
Ypsilanti, Michigan 48198
Posted: 01/24/13 09:22am Link  |  Quote  |  Print  |  Notify Moderator
The mattess heater cover heats well from below and works well. You can use an electric blanket, too. I do not need both.
wkswenson
USA - MA
Posted: 01/24/13 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Heated Blanket that is 12 volt could work...
Just an example
But if you go with a heated blanket or pad, 12 volt or 110 with an inverter... just make sure the cords are not anywhere they can get damaged potentially leading to a fire.
The 12 volt solution may not provide as much heat (no personal experience) but it might be enough to get that bed pre-warmed for you.
Walter & Donna Swenson
2013 Cedar Creek 38FL - Front Living, Trail Air
2002 F350 Crew Cab, DRW, 7.3L, Curt Q24K
Our Website - "A Work in Progress"
Fizz
Ottawa, Canada
Posted: 01/24/13 09:34am Link  |  Quote  |  Print  |  Notify Moderator
We have a small heating pad 12 x 24 inches. It lies between us on cold nights, does the job.
donn0128
Pronounced Ore-gun
Posted: 01/24/13 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Problem is that your foam mattress does not give up cold very fast. Do you use a dehumidifier in your trailer? We have found that unless we run ours when it is parked that everything is damp and cold for at least a day when we are out.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
The Texan
Meridian, Idaho
Posted: 01/24/13 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but this is not correct info. We have a heated mattress pad and a MSW inverter has been its power source for years.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
robsouth
Near Atlanta, GA
Posted: 01/24/13 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I'll take a good ole' electric blanket anytime. I prefer Biddeford dual control.
bazdad
Pensacola Florida
Posted: 01/24/13 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I do not plan to heat the bed while traveling but to plug into 110v before retiring for the night. Just want to warm the bed some to take off the chill. The question is still electric blanket or heating mattress pad. Thanks
sowego
northwestern corner of the Nebraska panhandle
Posted: 01/24/13 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Sure, an electric blanket or heating pad warms the bed but if the problem is only when you initially go to bed...buy yourself a large bag of plain rice, pour 2 to 4 cups in a sock, tie the top closed then heat in the microwave for 1-2 minute per sock. We use up to 4 larger rice bags in the bed in the coldest weather. The rice bags hold heat for hours and are a safe, economical, & easy way to keep warm.
* This post was edited 01/24/13 10:41am by sowego *
2002 Tiffin Phaeton
2005 Malibu Maxx toad
 > Heating Bed
