Woodalls Open Roads Forum: Anyone installed a product called "Cheapheat" ?
 > Anyone installed a product called "Cheapheat" ?
Page of 16
jrwhited
western pa
Posted: 02/23/13 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone installed an electric heat conversion kit called Cheapheat and if so your comments? Thanks
enblethen
Moses Lake, WA
Posted: 02/23/13 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure if I would want to try and modify my gas furnace.
It would be about as easy to install a small electric wall furnace.
Cheap Heat
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
PyrateSilly
Home
Posted: 02/23/13 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
We put in an electric fireplace instead for way cheaper. We have the room to do and it looks nice. I can also have just the "fire" on anytime we want the ambiance summer or winter with or without the heat part.
Thom, Gascap and Christine having fun in a 1993 Monaco Crown Royale 40ft 300hp RV.
Our blogged repairs and travels
hammer21661
Eastern Shore MD
Posted: 02/23/13 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
They should have those on all of the campers from the factory!!!!!
07 Ram 3500 Quad cab DRW Cummins 6.7,6 speed auto, Larime 4x4 long bed (affectionatly known as "Super-awesome-mega-truck")11/17/12
05 Kubota RTV 900.
04 Club Car Precident
2013 fuzion 322 all the bells and whistles.8/25/2012
2000 Yellow Lab mix Dog , Earl
Fizz
Ottawa, Canada
Posted: 02/23/13 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't find anywhere on that web site how many BTU it puts out.
If they can't give out the most important bit of information it can't be good.
pianotuna
Regina, SK, Canada
Posted: 02/23/13 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
The unit puts out 6,657 btus (1951 watts). It is nicely designed but fairly expensive. They used to have a 30 amp and a 50 amp unit. The 50 amp unit put out a lot more heat (of course).
There is no "fail over" to the propane furnace if the power happens to go off. It can not be used to assist the propane furnace. The system is either/or.
I prefer to use 1/2 size oil filled heaters in space that is otherwise not too useful. I've replaced the cold air return grill with a dual window fan unit that is controlled via a mechanical thermostat. That prevents the fresh water system from freezing up.
Some other folks have installed base board heaters which works well, too.
* This post was edited 02/24/13 06:51am by pianotuna *
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
nitrohorse
pa
Posted: 02/24/13 04:51am Link  |  Quote  |  Print  |  Notify Moderator
Cheap heat for my unit would be $495. I can buy plenty of small ceramic heaters for that price....
harold1946
Surprise Arizona
Posted: 02/24/13 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Installed one two years ago. 17,000 BTU. Cost was around $600 complete. It will maintain 72 degrees down to about 10F on our 35" motorhome.
It took me about 15 hours for me to install.
With our AGS system, if there is a power failure it will start the genny, or the flip of a switch and it goes to LP.
* This post was last edited 02/26/13 06:07am by harold1946 *   View edit history
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
pianotuna
Regina, SK, Canada
Posted: 02/24/13 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Hi nitrohorse,
And the heaters can be used in conjunction with the propane furnace to reduce propane use in extreme cold. The Cheapheat can not be used in that way.
allen8106
Burrton. KS
Posted: 02/24/13 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what brand furnace you have but Atwood definitley does not recommend the Cheap Heat. Check out the link below.
http://www.atwoodmobile.com/manuals/11-11CheapHeatInfoNotice.pdf
2010 Eagle Super Lite 315RLDS
2009 GMC Sierra 2500HD 6.0L
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Camping Nights 45
2011 Camping Nights 75
2012 Camping Nights 127
2013 Camping Nights 12
Page of 16
