Woodalls Open Roads Forum: how do I repair a stripped out screw hole in the wall
 > how do I repair a stripped out screw hole in the wall
harley-dave
ummm, where are we again..
Posted: 03/24/13 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Well, the subject says it all. My Winnie has those thin wood walls and some of the screws holding misc. plates and brackets are stripping out. How do I repair the holes so I can tighten the wood screws and keep thing from coming off the wall? [emoticon]
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
SKP # 121272
donn0128
Pronounced Ore-gun
Posted: 03/24/13 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Down and dirty simple fix? Take a tooth pick and some Elmer's glue. Apply a small amount of glue to the tooth pick and shove it in the hole. Once the glue is dry, replace the screw. Good for nearly ever. BTW this is a great fix for particle board holes too.
The Other Dallas
Over 1,200 volunteer hours
harley-dave
Posted: 03/24/13 08:23am Link  |  Quote  |  Print  |  Notify Moderator
thanks donn0128, I like simple fixes. Simple and durable is even better. I had thought about glue but needed an idea on something to put in the hole to make it smaller.
rk911
Wheaton IL
Posted: 03/24/13 08:28am Link  |  Quote  |  Print  |  Notify Moderator
been using this trick for a while now and donn's right...the repaired hole will hold for a long, long time. but, depending on the size of the hole, you may need more than one toothpick.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
marspec
West Virginia
Posted: 03/24/13 08:30am Link  |  Quote  |  Print  |  Notify Moderator
My son says the mechanic's fix is to use wire instead of a toothpick. While that works in metal I'm not so sure about wood. I'm going to try it on my yard gates where the latch screws come loose regularly with the toothpick method.
2013 F450
Towing 2013 Lifestyle 37RESL
RVhiker
Posted: 03/24/13 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Another way is to use a small plastic sheetrock wall anchor. It can just push into the too-large hole, and will stay in the hole if you have to remove the item that is attached.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
tvman44
Southwest Louisiana
Posted: 03/24/13 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I never would have tried that with that thin paneling, I would have replaced the screw with a molly bolt "it would be permanent" that paneling is so thin. [emoticon]
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
The Texan
Cascade, ID - Wellton, AZ - Toquerville, UT
Posted: 03/24/13 08:33am Link  |  Quote  |  Print  |  Notify Moderator
We also have used this trick for years. Our RV has many toothpicks in it. Simple fix and last, most of the time, forever.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/ 2016 Rzr 900 & 2013 Rzr 570 riding in 24' trailer in back.
Where the wheels are stopped today
JJBIRISH
Butler, PA, USA
Posted: 03/24/13 08:36am Link  |  Quote  |  Print  |  Notify Moderator
I to use the toothpick trick, but that isn’t the answer for your promlem…
Screws will never hold well in thin wood paneling… you need to install one of the the types of wall mollies available to hold especially while bouncing down the highways…
harley-dave
Posted: 03/24/13 08:37am Link  |  Quote  |  Print  |  Notify Moderator
thanks all. You guy's are making this entirely too easy!! I'm going to have to screw around on a few holes just to say I had to work at it!!
Dave
