Woodalls Open Roads Forum: Tent Camping: How to inspect my breaks?
Search only in Tent Camping
 > How to inspect my breaks?
komodo
Lasalle
Posted: 04/10/13 09:28am Link  |  Print  |  Notify Moderator
On my Rookwood HW277, tent trailer, I have AL-KO Hub and drum brakes.
I would like to inspect the brakes now and then. Does anyone know the procedure to do this?
* This post was edited 04/10/13 12:47pm by komodo *
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
ScottG
Bothell Wa.
Posted: 04/10/13 09:32am Link  |  Print  |  Notify Moderator
To inspect the brakes you have to pull the drums. They last a surprisingly long time though.
Scott, Grace and Wesly
H0NDA eu2000i
Old-Biscuit
Verde Valley
Posted: 04/10/13 09:40am Link  |  Print  |  Notify Moderator
Yes, you have to pull the drums in order to get to brake assemble.
HERE is a link to Al-KO Website. From there you can click on your particular brake assemble for an exploded view of hub & parts list.
You can check operation of brakes by jacking one wheel up, grab top/bottom of tire and wiggle it (check for any movement) then spin wheel (should be slight drag from brake shoes) and pull the pin on emergency brake switch (while giving the wheel a really good spin..have helper pull pin.....brakes should engage/wheel STOP----need good charged trailer battery)
Terryallan
Foothills NC
Posted: 04/10/13 10:22am Link  |  Print  |  Notify Moderator
My supervisor inspects my BREAKS on a daily basis. I have a mechanic inspect my brakes.
Sorry had too, couldn't help it, please forgive me.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
komodo
Lasalle
Posted: 04/10/13 12:48pm Link  |  Print  |  Notify Moderator
Thank you, it’s corrected.
Shadow Catcher
NW Ohio
Posted: 04/12/13 05:06pm Link  |  Print  |  Notify Moderator
Unless you are not traveling much or have sealed bearings, bearings need to be serviced/inspected/repacked yearly this includes those that have greaseable hubs.Brakes are checked at the same time.
* This post was edited 04/12/13 05:50pm by Shadow Catcher *
komodo
Lasalle
Posted: 04/29/13 08:47am Link  |  Print  |  Notify Moderator
I tried to remove the drums to have a look at the brakes but was unable to remove them. I always thought that you simply pull on the drums and out they come. But not knowing this model I did not want to take a chance and break something.
Is there something special about these drums?
Shadow Catcher
NW Ohio
Posted: 04/29/13 09:04am Link  |  Print  |  Notify Moderator
I am getting ready to replace bearings and seals on mine so happened to be doing some research on procedure and parts needed.
These do not work the way automotive brakes do you have to remove the castle nut holding them on first.
If you have ever pulled off drum brakes you will find they can be a bit "reluctant". If they have some age and the brakes have worn a ridge inside the drum they may have to be loosened up first before you have to pry them off. The procedure from Dexter http://l.b5z.net/i/u/6149609/f/Instruction_Sheets/059-726-00A.pdf
