Woodalls Open Roads Forum: Samsung Refer Install Over Propane Heater (Height Issues)
 > Samsung Refer Install Over Propane Heater (Height Issues)
DSDP Don
Moorpark, Ca
Posted: 05/03/13 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
I know many of you have installed the Samsung RF197 in your coach, but there are a few coaches with the heater under the Norcold limiting the space for the install. I thought some might like to see how I installed mine.
The standard RF197 is 69 3/4" tall with the wheels in place. My coach had 70 3/4" from the top of the heater to where the refer doors will clear the roof (ceiling light and speaker).
The below picture is the cabinet once the Norcold was removed. I used a small hydraulic jack to break the floor out, rather than hammering. I jacked the floor up in a couple of places and it broke loose. I sawed it in half and pulled it out. Monaco did not spare the staples!
This photo shows the propane heater and a couple of issues that had to be overcome. The drain pipe had to be rerouted around the front of the heater and some lines and wiring tied up against the wall.
In this photo, I removed the pink insulation and replaced it with 3/4" foam board. I also rerouted the drain line. The two large white connections are removable unions. If I need to pull the heater, it will be tough, but doable.
This is a photo of the electrical for the refer, remounted on the edge of the exterior door. The upper outlet in the upper box has one plug run off the Magnum 2000 inverter. The lower outlet in the upper box is for the new Magnum 600 inverter.
The lower box has the original shore power line that does not run through the 2000 watt inverter.
If you look closely, there is a metal frame (angle iron) now mounted over the top of the heater. It's the same level as the heater and supported at the four corners. It basically creates a set of parallel rails that will allow a matching frame attached to the bottom of the refer to slide in with no floor being used.
Here is the frame made out of 3/4" square tubing that mounts to the bottom of the refer. By removing the refer wheels, I was able to shorten the overall height of the refer by an inch. I was able to use three refer frame screws to attach the frame to the bottom front of the refer and drilled two holes through the rear of the refer frame to connect at the back. I used two sided tape along with the screws to attach the frame to the bottom of the refer.
Once the frame was on, I used a furniture dolly as others had suggested to move the Samsung around the coach. With the square tubing frame and rail system, I was able to easily slide the refer in and out while fitting everything.
This photo shows a mount I screwed to the upper right rear of the refer. It is accessed through the original refer roof vent. The roof vent is framed in aluminum from the factory. I added an arm from the roof vent frame to this bracket to secure the top of the refer. I also used two sided type to assist in holding this bracket on.
This is the refer installed. I made the front rail system adjustable. Once the refer was in place, I was able to add shims to both front rails to lift the refer and make it sit flush in the cabinet.
I removed the wood trim that was at the top of the Norcold and turned it sideways, changing the trim from 2" to 3/4". I used black door edging foam around the sides and top to seal the gap between the frame and refer. It worked out to be a perfect fit.
I locked the refer in place by running a bolt through the rail system in the left rear corner (accessible through the exterior vent door) and through the rail system at the front of the refer.
I really scored here. The frame with large louvers that was originally below the Norcold and provided air intake for the heater was just the right size to still fit under the new refer without cutting it down. I left off the base/height adjuster cover that came with the Samsung.
The original frame with louvers used large 2" wide louvers that were actually attached to the back of the frame, not inside of it. I removed the louvers and ripped them in half lengthwise, giving me two louvers finished on one side. I cut their length by about an inch and then glued them back inside the original frame. I took a left over louver and made two spacers to keep the now thinner louvers straight. In this photo the louvered frame is just laying up against the reefer. Tomorrow I'll probably attach it with the same latches Monaco uses on their drawers to hold it in place.
This is a close up of the newly designed louvered door.
This is a side view of the installation.
I fired up the Samsung and it was at temp in about two hours. I checked the heat at the rear several times and could hardly notice any. I'll probably leave the outside access door alone to allow more air flow since this was a tight fit. I'll put some door screen over the vents on the inside to keep the bugs out.
I also fired up the heater. It produced very little heat under the refer. Most of the vents on the heater are air intake vents. Only the front edge of the heater box got warm. We rarely use this heater.
This project was not hard, but very time consuming. It took me four full days to remove and replace the refers. There was a lot of exacting measurements and metal fabricating.
Don & Mary
2014 Newmar Dutch Star 4018 - All Electric
Cummins 450ISL
2016 GMC Canyon 4WD Crew Cab
Jim@HiTek
Gresham, OR, USA
Posted: 05/03/13 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Worked for many years in the appliance repair industry and one of the things we knew would shorten the life of a refer was lack of air flow around and above the refer. Most refer manufacturers spec the open space required.
What specs are there for air space around the Samsung? It looks to me like you don't have enough air space at the bottom front, the sides, and the top. But then I don't have Samsung's installation manual in front of me.
Then, I wonder about that top rail of the louvered grill that's placed in front of the drip pan access? Seems to me that it might block a lot of air movement over the pan under the refer. That pan holds the drip water from the defrost cycle. The grill the refer comes with allows air to evaporate the water quickly because of the heat from the compressor, which convection vents up the sides and the back, and in most homes, over the top of the refer into the kitchen (which is why the top of a refer should be open - usually with a 2" air space). In your remodel, does that air escape out the original refer roof vent?
Just curious about air flow around the refer...but other then that, it's a beautiful job!
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
DSDP Don
Moorpark, Ca
Posted: 05/03/13 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Jim.....The Samsung has no drip pan. There is no floor under the refer, the OEM vent on the exterior of the coach is still in place and is directly behind the compressor. The roof vent is also still open. The wood vent under front of the refer is wide open to all sides of the refer. In 90 degree weather today and the refer running to catch up after I unplugged it to add batteries, there is no discernible heat at the rear of the refer. This is one of the reasons a lot of people are choosing the Samsung, it's perfectly suited for this situation.
John & Angela
World Travelers.
Posted: 05/03/13 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Great job. Brings back memories of when we installed our 22 cubic foot whirlpool. We also had the furnace underneath. Way fun. [emoticon].
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
RedG
Fort Worth Texas
Posted: 05/03/13 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice job!
With the floor open, won't you get some wind blowing in from the fridge sidewall vent into the coach? Or is it sealed off in some way?
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
nemo45
Arlington, WI
Posted: 05/03/13 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
How did you get the Samsung into the motorhome?
Don Niemeyer
2006 Gulf Stream Tour Master T40A
2011 Chevy Equinox LT1 Toad
The Texan
Cascade, ID - Wellton, AZ - Toquerville, UT
Posted: 05/03/13 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
On our Monaco coaches, you just need to remove the doors and it will fit through the coach door, or if you want, remove the drivers side window and it will fit through that.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/ 2016 Rzr 900 & 2013 Rzr 570 riding in 24' trailer in back.
Where the wheels are stopped today
John & Angela
World Travelers.
Posted: 05/03/13 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know how he did it but we brought ours through the windshield.
DSDP Don
Moorpark, Ca
Posted: 05/04/13 04:29am Link  |  Quote  |  Print  |  Notify Moderator
As "The Texan" said, it came through the front door. I had to unscrew the arm at the top of the door that prevents it from opening past 90 degrees. This allowed the door to swing all the way open, adding 2". I have a manual door awning, so I had to remove one of the awning arms (5 minutes). I also removed the passenger's seat and laid it on the sofa.
The Norcold is only 24" deep when the doors and hinges are off. My front door is 26" wide. I used the cardboard from the refer to protect the dash. It takes two young guys or three old guys to get it out. The Samsung is very light when the doors and shelves are removed.
My onboard Energy Management System shows that the Samsung is only drawing 2 amps or less when running. The refer is rated at 3.9 amps max draw which probably would include start up and ice maker running all at the same time.
Galvanizd
Oregon Coast, For a bit.
Posted: 05/05/13 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Good job. I had hopes of doing this also but it was not to be. My 03 Dipl has the low ceiling and the furnace below the refridge. Didn't want to give up the furnace , so I went with the Amish cooling unit. Put it in last week. Works fine. Hope yours work good for you.
