Woodalls Open Roads Forum: General RVing Issues: Tire Speed Rating Question
 > Tire Speed Rating Question
Page of 7
Francesca Knowles
Port Hadlock, Washington
Posted: 07/19/13 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'm posting this here because the speed rating of a tire seems to me to cross all lines/types of vehicles.
Reading up on warranty issues/questions just now, I came across the following language w-a-a-a-y down the page at Firestone/Bridgestone tire FAQ's
Firestone/Bridgestone wrote:
The tire’s speed rating is void if the tire is repaired..... snip for clarity.....It should be treated as a non-speed rated tire.
That's repeated in the warranty published at this link (page 14)
What the heck does that mean?
D & M
Laurel, MD
Posted: 07/19/13 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
It means that the basis used to give the tire a speed rating is canceled because the integrity of the tire has been compromised. You can no longer count on that information being true. It could fail at any speed and the manufacturer does not back up the original rating
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (a Boston)
Izzy, Pepper & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
My computer beat me at chess once; but it was no match for me at kickboxing.
turnipbwc
Wheeling WV
Posted: 07/19/13 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
D&M,
By the looks of your map you need to head west and see the rest of USA.
'95 Dodge Roadtrek 190 Versatile,
'01 Chevy Silverado 1500 4x4
'02 Subaru Outback LT
BeerCan
Sticks of Fire
Posted: 07/19/13 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
If the tire gets a puncture/flat and you have it plugged or patched the warranty is void. IIRC a non speed rated tires speed rating is 85mph. If that makes sense.
D & M
Laurel, MD
Posted: 07/19/13 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
turnipbwc wrote:
D&M,
Just a soon as I put in the retirement papers and move out of this little slice of heaven.
bukhrn
Lanexa, Va
Posted: 07/19/13 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
turnipbwc wrote:
D&M,
And this pertains to the OP's question..how?
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
You can have my RV, when you pry my cold dead fingers from the Steering Wheel
nevadanick
Elko, Nevada
Posted: 07/19/13 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Beercan, how do come up with that ?
tatest
Oklahoma Green Country
Posted: 07/19/13 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
To understand what it means to be non-speed rated, you need to know what the speed rating means.
An example tire, in original undamaged condition is run under load against a test wheel, under standardized test conditions, at the rating speed, for a limited time period. Last information I've seen, the test period was 30 minutes, the test conditions much less severe with respect to heat, than typical summer highway conditions.
The DOT speed rating requirement came out of a series of tire failure accidents in the muscle car era. If a car is not limited to 85 mph (the magic number on our speedometers that was the first atttempt to fix the problem) then manufacturer has to install original equipment tires speed rated for the design top speed of the car.
This does not mean the tires can be driven all day at the speed rating, but does mean when the tires are new they should not come apart when the car is briefly driven at that speed. If the tires are damaged, the cannot be expected to perform as if undamaged, and the warranty language is the tire manufacturer's legal "out" for your expectation that it is safe to drive your car 140 mph because the tires were V rated when new.
It is not correct that unrated tires are rated for 85 mph. Certain classes of unrated tires, such as P-metric passenger car tires, are subject to testing at 85 mph, but that is not the same as a rating. Other types of highway legal tires, like trailer tires, might be tested at lower speeds.
Tom Test
Itasca Spirit 29B
Francesca Knowles
Posted: 07/19/13 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I'm following pretty well, but...
I'm still unclear about the practical effect of "speed derating" due to a puncture. Clearly, the tire's O.K. to go back on the road or Bridgestone wouldn't allow it to be repaired at all, right?
But what's its top speed? Is there a minimum speed rating that ALL P's or LT's must meet in order to be "legal", and does it just drop back to that?
I'm also still unclear as to effect on warranty, if any. Nothin' in there about one puncture wiping it out but I guess that wouldn't be any big surprise!
pronstar
The LBC
Posted: 07/19/13 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Maintaining/voiding a repaired tire's speed rating is dependent on the tire MFR.
Some void it, others don't.
Without digging too far into each tire MFR's website, The Tire Rack has a bunch of info all in one place:
The Tire Rack link
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
Page of 7
