Woodalls Open Roads Forum: Travel Trailers: Water pump location question
 > Water pump location question
Matt and Jerie
Santa Clara, CA
Posted: 07/28/03 01:24pm Link  |  Print  |  Notify Moderator
We have a 2002 Sunnybrook 26FK. The water pump is located right under the sofa bed and is quite annoying to our daughter who sleeps there. Is there any problem with moving it to the underside of the TT other than cold temperatures? It seems it would be a lot quieter if it were underneath. The next question has to do with the battery charger. Is there any problem with re-locating it to the under side of the trailer? Thanks for your anticipated help...
Matt of Matt and Jerie
2002 Sunnybrook 26 FK
1999 GMC Suburban, 1500 with 350
wesmitsi
Stillwater, OK
Posted: 07/28/03 02:25pm Link  |  Print  |  Notify Moderator
The water pump can go anyhwere the power and pipes can reach it. As long as it's protected from the weather and damage, it's ok. Might try insulating it beforee moving it. Make sure it's attached well. Make sure pipes don't rub or wiggle. Foam pipe insulation deadens alot of the noise. Some newer pumps like Shur-Flo are alot quieter than the ones (read - chaepo) used by the manufacturers.
As for electrical appliances, if they are weather and damage secure, the only factor becomes wire size. The longer the wires, the greater the resistance. More resisteance = more heat and less current. Try to keep wire runs to straightest and shortest route possible. May need to use heavier wire.
2001 F250 PSD
2005 Nash 31W
gstanton
Oakland, MD and Tierra Verde, FL
Posted: 07/28/03 02:42pm Link  |  Print  |  Notify Moderator
Agree with everything westmitse says - you might also try adding, I think it's called, an "accumulator tank". It's a small tank that holds approx. 1/2 gal or so of water with an air bladder in it, just after the water pump. It cuts down on how often the water pump comes on because it increases the volume of water available before it needs to pressure up again.
Dusty & Lindsay
Sadie the "Lassie" type Collie -13 yrs.
Maggie the Golden Retriever - 1 yr.
Oakland Maryland and Tierra Verde, FL
Our 3rd TT is an '02 26' Nomad Scout
Ford F150
Matt and Jerie
Santa Clara, CA
Posted: 07/28/03 11:48pm Link  |  Print  |  Notify Moderator
Thank you very much for the info...I'll try the insulation first
missouguy
Springfield, MO USA
Posted: 07/29/03 01:40am Link  |  Print  |  Notify Moderator
You can get a one gallon accumulator tank at Lowe's for about 40 bucks.
Frank & Gail
'02 F250 SD CC SB 7.3 TD 4X4
2001 Sunnybrook 33BWS Big Slide
MitchF150
NW
Posted: 07/29/03 01:48am Link  |  Print  |  Notify Moderator
Just turn the pump off at night. You should be able to get at least 4 flushes with the pressure in the system. Should also get enough pressure to get some water out of the faucet too.
I turn the pump off at night because the little light illuminates the entire trailer! But found it nice to not hear the thing when nature calls in the middle of the night too.
1997 F150 XLT, 4x4, SuperCab, ShortBox, 5.4, 3.55 gears, Prodigy, EAZ-Lift WD hitch, Autometer Water/Trans temp gauges, 200,000 miles (GVWR #6250 GCWR #12500)
2003 Prowler Lynx 722F (GVWR #5000)
