Woodalls Open Roads Forum: Class A Motorhomes: Cost of front brakes??
 > Cost of front brakes??
stroza99
NY
Posted: 08/20/13 10:52am Link  |  Quote  |  Print  |  Notify Moderator
We just had our front brakes and calipers done. What would an avg cost be for a ford F53 chassis? We were charged $150 for the pads, $302 for the calipers and 3 hours labor @ $95 per so it was like $750 and we thought it was high? It is the 1st time we had it done since getting our class A in April of '12 and its a 2002 with 16,000 miles on it! Thanks for all input!!
2014 Jayco Jay Flight 33RLDS
“Life is not a journey to the grave with intentions of arriving safely in a well-preserved body, but rather to skid in sideways, thoroughly used up, totally worn out and screaming... Holy Cow!! What a ride!”
V10guy
Medford, OR
Posted: 08/20/13 11:14am Link  |  Quote  |  Print  |  Notify Moderator
The recall on my front brakes was just done on my WH. It was $350 for two new calipers including labor(no pads were done). Yours sounds a little high, but doesn't seem outrageous...
Did they flush the brake fluid too?
Wife and I, 3 Kids(10, 9 & 6) 2003 Forest River Windsong 32' 8.1L Workhorse w/Allison. TOAD coming soon...
jcgribks
Olathe, Kansas
Posted: 08/20/13 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Here's prices from O'Reilly Auto Parts.
Front pads - $26.99 and $29.99 for semi-metallic and $94.99 for carbon metallic.
Front calipers - $73.99 - 122.99 depending on mfg and mounting locating (rear mount or forward mount).
3 hrs labor @ $95 = $285
They also probably charged you list price on all parts which would be higher that these prices.
$122.99 x 2 = $245.90 + $94.99 + 285 = $625.89 + tax and shop supplies.
I don't understand why you needed brakes anyway with only 16,000 miles on it.
1996 Itasca Suncruiser 34RQ, P32 w/ 454 TBI, Banks Air Intake, Harris Towmaster Performance Chip pulling a 2012 Jeep Wrangler Unlimited.
MountainAir05
New Mexico
Posted: 08/20/13 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Here locally the pad are around $66 for the pair and almost the same for each side rebuild. New ones are $128 each exchange. 16000 miles is not much for this vehicle to need new front or rear brakes.
stroza99
NY
Posted: 08/20/13 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
It was just for the front brake pads and calipers no back breaks were needed. And I know they cleaned the roters and sensors. I don't think they flush the fluid but will ask when I get it in a few hours.
John Wayne
Long Beach, Ca
Posted: 08/20/13 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
If the fronts see if they also repacked the front wheel bearings and put in new seals. As long as they had it apart.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 118,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
CloudDriver
New Jersey Shore
Posted: 08/20/13 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
For the front pads and calipers on our E450 Chassis, I paid $446 for the parts from Ford. Labor was my own in the driveway, but 2-3 hours seems reasonable.
I did the job at 80,000 miles because I thought one of the calipers was sticking. The pads had lots of friction material left, but I changed them anyway.
2003 Winnebago Minnie 24F - Ford E-450">
wolfe10
Posted: 08/20/13 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
The need for a brake job after only 16k miles would likely suggest that the caliper slides had frozen up or other mechanical issue.
Would be interested in knowing what the shop said was the reason for the failure.
Brett Wolfe
2003 Alpine 38'
FMCA Forum: www.community.fmca.com/index
Diesel RV Club:http://www.dieselrvclub.org/
Geocritter
Somewhere on the road less traveled...Presently NM
Posted: 08/20/13 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I do nearly all my own mechanical work. When I used to live in the Chicago area I learned to replace my caliper assembly on my Caravan at every second brake job (I'd typically get about 35K out of my front brake pads). The problem was the winter road salt would get into the calipers and cause the pistons to stick and bind. Living here in Texas it's a different story. My current Caravan has 145K on it and still has the original caliper assemblies.
Steve
nelson
Clio,Mi USA
Posted: 08/20/13 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I just did this job myself a few months ago Pads, Calipers, Rotors and Flex Brake Lines and I had about $450 in parts. All my parts came from Car Quest auto parts. You can find most of there parts on line, Ford did not have them, Told me to go with after market. Go figure.
