Woodalls Open Roads Forum: General RVing Issues: Wheel bearings
 > Wheel bearings
Page of 7
mark5w
Lehighton, Pennsylvania
Posted: 10/24/13 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
What is so different with RV wheel bearings that they have to be packed at least every year or two. My truck and car does not require this yearly maintenance, why does the RV axles??
Mark ">
Susan ">
K Charles
Connecticut
Posted: 10/24/13 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Our last TT had about 30,000 miles on it when we traded it in and I never took off a wheel. I adjusted the brakes once that was it.
ScottG
Bothell Wa.
Posted: 10/24/13 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
They don't.
The manufacturers make the statement to cover their arses. I wen't 9 years without servicing mine. Just checked for looseness and adjusted the brakes. After that nine years (and about 45K miles) I serviced them and you know what?
They didn't need it.
As long as they are lubed and set up correctly in the first place they don't need re-lubing any more often than you do on a car - when you replace the brakes.
Scott, Grace and Wesly
H0NDA eu2000i
2oldman
OTR
Posted: 10/24/13 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Some RV's bearings need more attention because they sit a lot. I don't service mine every 2 years, in fact I serviced after 10 because one wheel was getting hot.
time2roll
Posted: 10/24/13 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
The first repack is important to verify the factory build.
Once you know they are assembled correctly you can extend the service IMO.
2001 F150 SuperCrew
675 watts solar
MTPockets1
USA - Usually West
Posted: 10/24/13 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
If you are parked for several months there is a chance for that spot where the roller contacts the bearing raceway to begin corrosion. The storage environment dictates. Changes in temperatures may introduce moisture which leads to surface rust which leads to wear problems later. Proper lubrication is key, but if you store for several months at a time, an annual check is wise. An alternative is to store on frame blocks and spin wheels by hand a few times during storage. This keeps the bearing surfaces well coated and the load off the bearing rollers.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
JJBIRISH
Butler, PA, USA
Posted: 10/24/13 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
One it’s the RV industry, that buys everything at the lowest possible price… the auto industry specifies a level of quality at the lowest price…
The bearing industry is large, lucrative and now ripe with imported counterfeits in this country and I assume around the world… counterfeits that are so good these days the big bearing companies have a hard time telling the apart… one of the benefits they get by moving production to a country like China…
The bearings in the RV are placed under high stress especially with the trailer industry undersizeing running gear to improve profit… they can’t place safety over profit, they have a reputation to uphold…
Also bearings and their lubricant that are put through high stress and then left to sit for long periods of time have a tendency to fail sooner… and thats the good bearings!!! During the long storage period the oils also have a tendency to separate from their carrier causing poor lubrication when it’s needed most…
Good bearings properly sized and used on a regular basis in automotive use could easily last from showroom to the scrapyard without ever being serviced… that’s not to say that is a good idea or the best approach, just one that happens very often…
Posted: 10/24/13 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have packed my brains twice since the trailer was New in 2006. This represents over 80,000 towing miles. I watch for signs of leaking Grease on tires or breaks and would service them if I found anything but so far I have not.
D & M
Laurel, MD
Posted: 10/24/13 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Never packed bearing on any rv I have had. Like someone else said, the RV manufacturer is CYA.
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (a Boston)
Izzy, Pepper & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
My computer beat me at chess once; but it was no match for me at kickboxing.
Water-Bug
Banglidesh
Posted: 10/24/13 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I've racked my brains over a lot of things but never tried packing them. Come to think about it, I've pickled them a time or two also.
Page of 7
 > Wheel bearings
