Woodalls Open Roads Forum: General RVing Issues: Tires for 5th wheels
 > Tires for 5th wheels
skelsey74
Full Time
Posted: 11/05/13 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have had my second blowout in three months. I was informed that the Carlisle is often referred to as a China Bomb. Okay now I am in the market for four new tires. I believe my rig fully loaded is around 14k pounds. I have run usually short distances under 50 miles, stay at 55mph or less depending on conditions and weather. I am really scared right now which way to go. I have heard Goodyear Marathon, Kuomo, and Power King are the ones producing the kind of tire that I can put on. I have 235 85 16 with very little clearance between 1st and 2nd axle. I was told by every shop in the local area I am at that Goodyear was manufactured here, but wrong! I guess all tires come from China now. Also since I stay in rather warm weather all year around. I was told to help keep the tires cooler is to use nitrogen. I travel alone, and feel that I need the best tire I can afford to put on the rig. I have owned it since March 08 and this will be my third set. Suggestions, help anything, to set my mind at ease.
donn0128
Pronounced Ore-gun
Posted: 11/05/13 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Lt tires have lots of choices
The Other Dallas
Over 1,200 volunteer hours
1492
Washington, DC
Posted: 11/05/13 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support
Dick_B
Palos Heights, IL USA
Posted: 11/05/13 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I really like my Michelin XPS Ribs
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
rseymour21
Dallas
Posted: 11/05/13 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
X2 - I changed from 15" wheels to 16" wheels just to go with LT tires!
2003 F250 7.3L
2008 Cougar 292RK
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 11/05/13 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
If the 235/80/16 will fit.. then go with Maxxis. Do a search on this forum and you will find that's the top rated Trailer Tire for people on this forum.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS; 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; 2015: 2006 Class 'B' Chateau Citation; "(Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 11/05/13 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum! To help you we need a little more info.
Year, make and model of the trailer.
From the Placard on the front left side of the trailer.
GAWR, GVWR, and OEM tire size and load rating.
Then measure from center to center of the axles and provide that measurement, along with some clearance measurements above and behind the tires.
Chris
2015 RAM 3500 CC SB SRW Our Rig New 2017 Bighorn 3575el. Retired and enjoying it!
the bear II
Torrance CA.
Posted: 11/05/13 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
X2 after months of research on RV and Truck forums these tires had the highest ranking. Plus most folks indicated they got way more mileage out of these tires than others.
I bought a set of 4 two years ago for my 15000 lb 5th wheel
skelsey74
Full Time
Posted: 11/05/13 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
04 Hitchhiker LS 32.5 double axle. The original tires were Goodyear 235 85 16. There is very little space between the first and second axles about two inches!
Ric Flair
Posted: 11/05/13 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Goodyear G614's
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
