Woodalls Open Roads Forum: The Old Drain Hose Under the Tow Vehicle Trick
 > The Old Drain Hose Under the Tow Vehicle Trick
Page of 6
TechWriter
On The Road
Posted: 11/11/13 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
We're in a mostly Winter SnowBird campground, but had a couple spend the weekend next to us. And by "next to us" I mean a few feet as this is a Pack-Them-In type campground.
Last night I noticed that the couple had run a hose from their popup under their SUV. Thought nothing of it other than it was unusual.
However, this morning I noticed a very large wet area under most the the SUV. It was easy to spot because all the campsites are dirt. So the wet area stuck out like a sore thumb.
I contacted the camp management because I didn't want to deal with these yahoos, and it looks like the couple were fined before they left. I hope so.
Even if they were just draining water, it created a great big mud puddle right next to us -- and this campground had two dump stations -- so they still would have to dump anything else they had onboard.
Takes all kinds.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
doxiemom11
Mississippi
Posted: 11/11/13 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
You can't cure stupid!
D & M
Laurel, MD
Posted: 11/11/13 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
ah, never mind
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (a Boston)
Izzy, Pepper & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
My computer beat me at chess once; but it was no match for me at kickboxing.
Dog Folks
Naples, Fl. USA
That is a special kind of stupid right there.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
Posted: 11/11/13 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Many pop up trailers do not have holding tanks so they likely were running gray water onto the ground. Fortunately it's also true that MOST pop up trailer don't HAVE a fixed toilet so it probably WAS gray water. Why run it UNDER the TV? Probably because it's against RV Park rules to dump water at sites. When I use my pop up I have a 5 gallon jerry can into which my gray water is collected for disposal at the dump. SOME also use a blueboy (one of the few advantages I see to using them). Stupid of lazy, the result was the same, a mud hole in an RV parking lot.
Good luck / Skip
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Posted: 11/11/13 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
The problem, for me, with dumping gray water directly on the ground is that it draws flies. You try and eat outside and flies are on your food.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2013 Honda Accord EX-L · 2008 Honda Odyssey EX-L
Hank MI
Brighton, Michigan
Posted: 11/11/13 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
It's not stupid, it's 'I don't care'. I don't care what the rules are, I don't care about the other campers, I don't care about the environment, I just care about me.
Bob & Ann
North AL
Posted: 11/11/13 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on the flies. Gray water also has an odor to it and the rest of the campground does not need to smell the odor because of one persons laziness.
Bob and Ann
One HAPPY Schnauzer - Della
One FRISKY Chihuahua - Lola
Tiffin Motor Home
2014 40 QBH Phaeton
Freightliner Chassis
Cummins ISL 380 HP/150 Torque
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2014 Jeep Wrangler Unlimited Toad
Demco Dominator & Airforce One
ontheroad101
Flordia
Posted: 11/11/13 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I hope the fine was enough to help cure stupid. Just maybe they will learn because of the fine
Super Wife Linda, me Bob &
(Blazer & Lilly's ashes on board)
2014 Forester Class C, our Blog http://www.bobandlindasrvtravels.blogspot.com/
Sea Eagle Fishermen & Kayak
resmas
temporarily displaced Alaskan
Posted: 11/11/13 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Gray water that has been in a holding tank can stink almost as bad as the black tank contents. But gray water coming out of a pop-up is likely fresh from the sink, and wouldn't smell any more than a sink full of water does when you wash dishes or wash your hands. And it shouldn't smell on the ground any more than what results after a person washes a vehicle...
It is possible that these campers simply did not or do not know that you can purchase totes to drain the gray water into to transport to a dump station. I wouldn't have been quick to jump on them, but I would have approached them in a friendly manner to suggest they change their practices.
2012 Dutchmen Voltage Epic 3795
2010 Dodge 3500 DRW MC
2009 GMC 2500 DA CC
2012 Smart-for-two (sometimes hitches a ride in the Voltage!)
2005 Sundowner Sunlite 777
Page of 6
