Woodalls Open Roads Forum: General RVing Issues: Do you?
Cummins12V98
on the road
Posted: 12/08/13 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I have noticed quite a few people that have their RV tipped to the drivers side when they are set up. I assume this is so the waste will flow easier. I also am wondering if those people leave their black tank valve open?
Does not look like it would be very comfortable being that much out of level.
2015 RAM LongHorn 3500 Dually CrewCab 4X4 CUMMINS/AISIN RearAir 385HP/865TQ 4:10's
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2016 MobileSuites 39TKSB3 highly "Elited" In the stable
2007.5 Mobile Suites 36 SB3 29,000# Combined SOLD
brirene
midwest
Posted: 12/08/13 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I can't recall ever seeing that, not that I was looking for it. I think most people strive for close to level. I assume tanks are designed to drain when unit is level, more or less, and don't need the extra slope. I sure wouldn't want to be unlevel to the point of discomfort.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Dog Folks
Naples, Fl. USA
Posted: 12/08/13 11:45am Link  |  Quote  |  Print  |  Notify Moderator
We tip ours 1/2 bubble off level side to side and front to rear to improve water flow off the roof and flowing away from slide seals.
This is not enough that you would even notice unless you have a level. We also "tip" the awning to keep water from pooling on the fabric.
We keep our tank valves closed until the tanks are nearly full.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
GMandJM
NoVa (In English & Espanol)
Posted: 12/08/13 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Can't say that I have seen that much, either. We always try to get as perfectly level as possible.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
rvten
Crossville,TN
Posted: 12/08/13 11:53am Link  |  Quote  |  Print  |  Notify Moderator
You sure it Is the RV that is tipped to one side? LOL
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
tkcas01
Roaming Fulltimer
Posted: 12/08/13 11:57am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Good one. I've never noticed that either and certainly try to get as level as possible using the leveling jacks.
Roaming Full Timer
2004 Monaco Diplomat DST
2007 Jeep Grand Cherokee Toad
Don & Carolyn
Mnnesota/Arizona
Posted: 12/08/13 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
We lean slightly to the driver's side so the rain flows off the large slideout.
Don & Carolyn
2006 Dodge 2500 diesel 6 speed
17' Casita Independence Deluxe
Cummins12V98
on the road
Posted: 12/08/13 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
I am a Journeyman Carpenter so I should know what level looks like! SHOULD…HA
These rigs are literally listing to the drivers side 2-3". I am thinking they are the ones that leave the black tank open all the time?
Old-Biscuit
Verde Valley
Posted: 12/08/13 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I setup level/close to.
5vr roof is designed to drain water forward and aft when rig is level
Slideout roofs are designed to drain when rig is level
Waste tank drains are designed to evacuate when rig is level
Air conditioner run off flows to rear when rig is level
Fridge operates best when rig is level
The only thing I have to compensate for when rig is level is awning....I drop forward corner so rain runs off to forward corner away from entry door.
For me....set it and forget it (sorta like Ron Popeil) [emoticon]
Dog Folks
Naples, Fl. USA
Posted: 12/08/13 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe or maybe not. How about plumb and square? Just joshing you. LOL
