Woodalls Open Roads Forum: General RVing Issues: STANDBY GENERATORS
 > STANDBY GENERATORS
Page of 7
M GO BLUE
Southgate, MI
Posted: 12/26/13 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
We are looking to buy a new stick and brick house close to the grand kids and when completed want to equip it with a standby generator...
For those with a standby generator what fuel type do you have? LP? Natural gas?
Also our fifth wheel has an Onan 5500W gas generator built in...can this be used via a transfer switch to run the house if needed? is 5500W big enough to run the whole house?
Thanks for your time...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
Hank MI
Brighton, Michigan
Posted: 12/26/13 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have an auto standby gen but quite a few neighbors do. Here they're on natural gas and they do use a lot. If running a large whole house unit, say 15k watts it will run through a lot of propane and that will cost you. Natural gas is cheaper and always available.
As for the gen in your 5th wheel, it could be used if you know what you're doing. 5500 watts will run most everything. No central air but it will keep your furnace running, the lights on and most everything else. We have a 5500 watt gen and run the furnace, well pump, 2 refrigerators, deep freeze, lights, TV, internet. We also use the microwave, toaster oven, coffee pot, vacuum cleaner, etc. Just don't try to use all those other things at the same time. A little common sense, turn off things you don't need and 5500 watts will keep you going.
donn0128
Pronounced Ore-gun
If you have natural gas at the house then it is a no brainer, natural gas.
That is the biggest drawback of built in generators, you just can't take it to where you need power easily.
The Other Dallas
Over 1,200 volunteer hours
Padlin
W. Ma.
Posted: 12/26/13 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Those that I know that run MOST of their house have at least 8k watts, a lot depends on the house and your expectations.
Preferred would be LP or Natural gas. They make tri fuel generators too that take LP, Natural gas, or gasoline.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
rk911
Wheaton IL
Posted: 12/26/13 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
we have a 12KW Koehler stand-by genset powered by natural gas. as for your 5.5kw genny...depends on how big your house is and what yoyu mean by "whole house". we could've gotten by with a smaller genny if we didn't care about being able to run the central air with the genny but we did.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
sclark
New Mexico
Posted: 12/26/13 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to try Northern Tool. As mentioned above your RV generator will not be enough to run very much inside your home. As you mentioned you will need to use a Transfer Switch for every circuit you expect to run. Good luck with your project!
2013 Ram 3500 Crew Cab Cummins Aisin transmission
2014 KZ 358BHK
Honda eu3000is Generator
pianotuna
Regina, SK, Canada
Hi Go Blue,
Natural gas would be my first choice. Propane 2nd choice.
Regards, Don
Randu
South Central Michigan
Posted: 12/26/13 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Friend of mine north of Jackson has a Built in Natural Gas generator. It automatically starts when power goes off and shuts off when power comes back on. He don't touch anything. It starts up and runs to exercise once a month automatically also. Powers whole house including the well and I think he had about 5k invested including installation.
I use a 16 year old 8hp HONDA 5000 watt unit with a manual transfer switch and it powers most of what I need but am selective on what breakers I turn on. I have city water so don't need to worry about water pump but I do have a 220v going to a sewer grinder tank pump and central AC. I leave the grinder off and only selectively turn on when needed.
The RV generator would work fine and I have a friend in OH that uses his motorhome generator to power the house when needed. Just need a transfer switch wired in the house and maybe a plug in the RV with proper gauge wire to connect. Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison. (Picture is 2014 truck just traded)
2008 Mobile Suites 36TK3
ronfisherman
SE Michigan
Posted: 12/26/13 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 12KW standby generator on our home. It runs on natural gas. 200 amp auto transfer switch. It will run our whole house. Water pump, furnace, AC and anything else we have except the electric oven. Does not cost much to run on NG.
You could use your RV generator, It will require some wiring to get power to the house. It will run your furnace in cold weather. I was able to use a 5000 watt generator to keep water pump, furnace, freezer and fridge, Plus TV and lights.
If you are going to be in SE MI. I got mine from and installed by Marks Outdoor Equipment in Notrhville, MI.
2012 Chevy Captiva Toad
Super C Group Forum
CavemanCharlie
Storden,MN
Posted: 12/26/13 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would be afraid in a big natural disaster that the natural gas supply could be cut off too. Take for example a earthquake. The gas lines are going to break and when they do the gas is automatically shut off and then no more generator. Someone mentioned a tri fuel one that would be the cats meow because you would have 3 times the chance of finding some fuel somewhere.
My brother has a automatic transfer generator that runs on diesel fuel. But, for us on the farm that makes since because we have a lot of equipment that runs on diesel.
Page of 7
