Woodalls Open Roads Forum: General RVing Issues: What is wrong with my F150
 > What is wrong with my F150
Terryallan
Foothills NC
Posted: 01/24/14 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
It eats tires. The BF Goodrich Long trails that came on it lasted only about 20,000 miles. I put on some Cooper Discoverer Plus. Another 15,000 ish. Then I put on Michelins. And now at 65,000 miles on the truck. I'm getting ready to put on the 4th set of new tires.
Understand. The tires, all of them. Have worn evenly across the tire. The do not cup, and they are not out of round. I check the PSI regularly, and have them rotated at every oil change.
I'm just confused as to why they don't last. I kind of understood the Coopers. I pretty well burned them off. They were pretty hard, and being hard, were really easy to smoke. But I put a limited slip in, and stopped most of the smoking, But the Michelins are still worn down to with in 1/8" of the wear bars.
Am I alone in this?
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Bucky Badger
Madison, WI
Posted: 01/24/14 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
My BFs Lasted 35,000, My Coopers lasted about 65,000 Just put a set of BFs back on at just over 100,000
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
and
2009 Nomad 3980
GaryWT
MA
Posted: 01/24/14 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
The Michelins that came on the truck are still there at 62,000 miles. They are done but I was extremely happy with them. They are P tires and I will be going to LT tires to help with the towing.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
pappcam
Saskatchewan, Canada
Posted: 01/24/14 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Am I alone in this?
The fact you mention smoking your tires answers your own question...
2012 Flagstaff 27BESS
2011 F150 XLT 5.0
down home
south
Posted: 01/24/14 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure what mileage was on the truck when the Chinese tires got the last set of Michelins, which were the second set of tires on it. The second set of Michelins have been on it since 07. There is 174,000 miles on it. The tires have most of the tread. One problem I encountered was the insistence of the Folks that change the oil to set the tire pressure at 32 lbs. The Hancocks, that came on it didn't last long. I don't know what the pressure on the door sticker says but the Michelins run at 45lbs max and can be run ten percent over, on a light truck tire. I have to reset the pressure to 40 lbs, despite me telling them what to set them at. They say they have to set according to the sticker. Some people are so maddening. At 32 lbs the truck is somewhat squirrley, especially in curves. If I carry a load they go to 45 lbs.
Some Michelins in larger sizes run to 80 lbs for light truck tires. I feel really that the tires should be run at 45 lbs. The truck rarely sees any- speed though.
ford truck guy
Pennsylvania
Posted: 01/24/14 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have 19,000 miles on my 2013 F-150 and they still look new??? If your saying that they are not cupped or skuffed??? Maybe lay off the gas a bit and stop burning them at the lights,, your NOT 19 anymore!!! [emoticon]
Me-Her-the kids
2015 Ford F350 SD 6.7
2016 Redwood 38RL Black~Silver
Posted: 01/24/14 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
IF you are towing a lot of miles then 20,000 isn't that bad. It's about what I got on my old F 150 5.4 when I was towing 25,000 miles a year. My own strategy was to NOT rotate tires and replace the rear tires after about 20,000 miles and the fronts after 40,000 or so. Front tires NEVER showed ay wear other than evenly across the tire. Cut replacement costs by 1/3 that way.
dodge guy
Bartlett IL
Posted: 01/24/14 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Quote; " very easy to smoke the tires" "I put a limited slip in and stopped most of the smoking"
As was said, I think you know why the tires are wearing out!
Wife Kim ">
Son Brandon 13yrs">
Daughter Marissa 12yrs">
Dog Bailey ">
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam, Prodigy brake controller
A bad day of camping is
better than a good day at work!">
Oaklevel
MidAlantic
Posted: 01/24/14 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
We had an Honda Accord that went through 3 sets of Michelin's 20K each wore out to the wear bars(Back then they had an unlimited mileage warranty for the style so didn't pay for the next set until they ended the warranty & I ended using them) at about 60K changed brands to Bridgestone & got 60K each set till a deer ended the run at 229K
Back to trucks I had a Dodge Ram with the Hemi & could not keep rear tires on it never smoked them but there must have been just enough slippage from torque & the rear being so lite. If I remember right went through 3 sets in 90K.
Our tire guys loved us for a while were buying at least 3 sets a year between the vehicles & trailers. The DW & I put over 30K a year on our cars.
bguy
The Rock
Posted: 01/24/14 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
You need to alter your driving habits. I bet you find fuel consumption a little high? Try driving like it's slippery and that should take care of it.
2010 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
