Woodalls Open Roads Forum: One mans opinion on how to prevent another Atlanta
 > One mans opinion on how to prevent another Atlanta
Page of 8
CavemanCharlie
Storden,MN
Posted: 02/01/14 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I apologize if this post is considered inappropriate. I don't think it is though that's why I'm posting it. Anyway, a local weather forecaster from here in MN posted this on how he thinks we could avoid another Atlanta type snow storm problem
http://blogs.mprnews.org/updraft/2014/01........-prevent-the-next-atlanta-snowpocalypse/
nelson
Clio,Mi USA
Posted: 02/01/14 08:42am Link  |  Quote  |  Print  |  Notify Moderator
What about people using some common since. Weather predictions are just that perdictions so don't bet you life on it. Foresight is always 20/20,
Us out West
Eloy, AZ (winter - now), Reno (home base summer)
Posted: 02/01/14 08:51am Link  |  Quote  |  Print  |  Notify Moderator
To much so called 'good' info available now that the use of 'common sense' by many nowadays is not used...maybe they don't know what 'common sense' even is as they rely on others to make THEIR decisions and then get ticked off when things go bad.
[emoticon] [emoticon]
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
poncho62
Hanover, Ont, Canada
Posted: 02/01/14 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I guess its all what you are used to, but my Gawd, there is barely enough snow in those pictures to cover the ground. We get that much or more practically every winter day here. My back yard right now
I know the ice there compounded things, but people need to slow down and use common sense. We get those here to that think because they have a 4x4, they are invincible....not so
* This post was edited 02/01/14 12:41pm by an administrator/moderator *
WyoTraveler
Wyoming
Posted: 02/01/14 08:56am Link  |  Quote  |  Print  |  Notify Moderator
The problem is wx remains a prediction plus drivers in the north drive in those coditions every day and become experienced drivers on snow and ice. Some of the drivers in those states probably never drove in those conditions. Plus ice on hills is a problem anywhere without proper equipment and sanding trucks. Just speculation that it could be prevented.
rvjames
Georgia
Posted: 02/01/14 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Something about snow/ice makes people (myself included) in the south revert back to the first time they were behind the wheel of a car. The vehicles here are also not prepared for it. Most folks dont purchase vehicles made for winter weather conidtions (no front wheel drive or 4x4). Not to mention the tires, many of the people on the road in the south are riding on nearly bald tires because there isnt traditionally a need for anything else. Just a big mess that will probably never be fixed.
Us out West
Posted: 02/01/14 09:06am Link  |  Quote  |  Print  |  Notify Moderator
The use of common sense would fix most things.
robsouth
Metro-Atlanta, GA
Posted: 02/01/14 09:07am Link  |  Quote  |  Print  |  Notify Moderator
The three major Atlanta stations, the Mayor, the DOT folks,etc, have already said basically the same thing that this guy is saying, BUT...Feelings contrary to what the National Weather Services is putting out take second place. The NWS was wrong this time and the powers to be chose to follow the NWS advice and not the local advice..as the locals tend to "sensationalize" any weather event to the point you want to go into a bomb shelter for the duration and more often than not, they spend the next few days talking about what should have happened instead of what did happen. It is not easy to predict (not perdict) what will happen, else I would win all the lotteries. Lessons learned I think will help in the future.
westend
Shorewood, MN
Posted: 02/01/14 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Amen, the govt. mantra...don't rock the boat and pass the buck.
Old Minnesota isn't immune to poor planning with roadway maintenance, either. Someone over at MNDOT decided that plows aren't to be used while it's snowing and the deicing schedule has changed. I would bet both of these are due to budget trimming. In past time, plows were out at the first snowflake and sand/salt was spread so that intersections and roadways melted out before the storm had finished. Now, most of the secondary roads have sheets of built up ice that isn't going away until traffic or weather does the job.
FWIW, when I lived in Houston there was a local TV weatherman that was so poor on forecasting that they put his talents against a cow owned by a local rancher. Depending on the way the cow rubbed against the fences and moved in the corral indicated changes in the weather. They ran this contest for a month or so and the cow won out handily.
'03 F-250 4x4 CC
'71 Starcraft Wanderstar -- The Cowboy/Hilton
Escargot
California
Posted: 02/01/14 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Hindsight is always 20/20.
Opinions are like...
everyone has one.
It happened.
Lessons were learned.
Move on.
2006 Pleasure Way Plateau TS, MB Sprinter
Page of 8
