Woodalls Open Roads Forum: New Owner of an Used (1990) RV here-What do I need to know?
 > New Owner of an Used (1990) RV here-What do I need to know?
SirPorkalot
Bay Area, CA
Posted: 03/10/14 10:37am Link  |  Quote  |  Print  |  Notify Moderator
I have just purchased a used Class C, here are the particulars.
1990 24' Fleetwood Jamboree Rallye on a Chevy chassis with a (rebuilt) 454.
I am somewhat handy and expect to have to do regular maintenance along with some irregular maintenance/repairs due to the age.
While the beast seems to be in decent shape overall, and all systems seem to be (currently) in working order, I am looking for advice from the folks on here about what to look for going forward.
1. What are the typical issues/concerns with these models I need to stay in front of?
2. Any tips for upgrades to make the beast more efficient/productive?
3. What upgrades do I want to consider for dry camping? (solar panels/inverters, etc)
Thanks in advance for any help.
John
* This post was edited 03/10/14 11:03am by SirPorkalot *
donn0128
Pronounced Ore-gun
Posted: 03/10/14 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Water leaks and or water damage are your biggest concern by far. You might start with a seal test to see how many water leaks it currently has. Once you have those under control, then start searching for previous water damage.
Next on the line IMHO would be to have the gas system pressure tested.
Everything else will come.
The Other Dallas
Over 1,200 volunteer hours
crickeydog
Marietta, Ga.
Posted: 03/10/14 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum and congrats on yer new to you RV.
Typical issues and concerns for your type of RV is:
1. Water leaks.
2. Roof & window leaks, especially the front forward facing overhead window.
3. Water leaks.
4. Water leak damage behind walls and in sub-flooring.
5. Did I mention, water leaks?
6. Roof damage from lack of annual maintenance.
7. Water leaks.
Good luck.
Happy camping!!! See y'all down the road!!![emoticon]
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
gbopp
The Keystone State
Posted: 03/10/14 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum.
As mentioned, water leaks are probably your biggest enemy. Use Eternabond and Dicor Self Leveling Caulk for your roof repairs and maintenance.
Also, check the age of your tires. RV tires usually age out before they wear out.
Mich F
Plantation, Fl
Posted: 03/10/14 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Aside from checking for water leaks, were there any maintenance records with the coach ? Do you know when the anti freeze and transmission fluids were flushed/changed? How old are the tires - tread depth isn't as important as age ? Best of luck with your MH.
2014 Itasca Spirit 31K
Dick_B
Palos Heights, IL USA
Posted: 03/10/14 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Suggest you take at least one of the tires to a qualified shop to have them remove the tire from the rim and check the inside as well as the outside. If bad one can assume the others are also. Anything more than about 7 years old should probably be replaced.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
SirPorkalot
Bay Area, CA
Posted: 03/10/14 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Yes during my search I came to realize most all of these older MHs have issues with leaks.
I drove several hundred miles looking at RVs while it was raining and shortly after heavy rains and inspected/drove about a dozen older Class Cs, most with active (wet) leaks and/or active mold.
We quickly learned to look under any new contact paper, under beds, in hard to access corners, etc..
The one I ended up purchasing did have some water damage in the section above the cab, but it had been fixed by the previous owner who also resealed the roof, windows etc.
While there is not any evidence that I could find of active leaks or mold, I am sure these will crop up.
When you say Gas system pressure test, I assume you are referring to the LP system.
Is this just a simple leak down test or is it more involved?
John
SirPorkalot
Bay Area, CA
Posted: 03/10/14 11:01am Link  |  Quote  |  Print  |  Notify Moderator
That seems to be good advice.
I have read about blow outs on these monsters and going down a mountain is not when I want to find out I have a bad tire.
[emoticon]
I will take it to the tire shop and have them inspect all 6 tires and the spare.
John
SirPorkalot
Bay Area, CA
Posted: 03/10/14 11:03am Link  |  Quote  |  Print  |  Notify Moderator
1. Water leaks.
3. Water leaks.
7. Water leaks.
Good luck.
So......
You are saying there may be leaks??
[emoticon]
I'll keep my good eye open for any new ones [emoticon]
donn0128
Pronounced Ore-gun
Posted: 03/10/14 11:28am Link  |  Quote  |  Print  |  Notify Moderator
John
Most any dealer can do a pressure test for you for a reasonable charge. You might also call local propane dealers and see if they can do it too. Takes about an hour, they turn everything off and pressureize the system with compressed air and let it sit for about 30 minutes. If the Gage does not go down, no leaks. You really do not want a gas system leaking.
