Woodalls Open Roads Forum: General RVing Issues: slow moving vehicle sticker
 > slow moving vehicle sticker
Page of 9
pianotuna
Regina, SK, Canada
Posted: 03/19/14 09:32am Link  |  Quote  |  Print  |  Notify Moderator
I'm not into life in the "fast lane". I'm wondering if anyone has information about a "slow moving vehicle" sticker that could be placed on my RV.
Does anyone use one or have one?
Regards, Don
bhh
Cincinnati
Posted: 03/19/14 09:38am Link  |  Quote  |  Print  |  Notify Moderator
You can find them at about any farm store, e.g., Tractor Supply.
They are normally meant for off-road or agricultural vehicles being operated on a roadway temporarily. You might be in violation of some states' statutes if you put them on an RV or TT.
If you are going well below the speed limit on an uphill climb, I think you'd be better off just putting on your 4-way flashers for the duration. JMO.
For example, in Texas:
Slow-moving vehicle is defined as a motor vehicle designed to operate at a maximum speed of 25 miles per hour or less; or a vehicle, implement of husbandry, or machinery, including road construction machinery, that is towed by an animal; or a motor vehicle designed to operate at a maximum speed of 25 miles per hour or less.
CA Traveler
The Western States
Posted: 03/19/14 09:43am Link  |  Quote  |  Print  |  Notify Moderator
What are Canadian regulations regarding this?
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
750 Watts Solar MPPT 60 Controller
2004 Honda CR-V
Bob
BIKERK9
Igo, CA
Posted: 03/19/14 09:46am Link  |  Quote  |  Print  |  Notify Moderator
There are vendors that make Bumper stickers and Decals to order. I have seen a bumper sticker "I do not drive above 55"
Whenever you can not keep up with the flow of traffic, stay in the far right lane and put your emergency flashers on. They can be seen from a greater distance allowing others to pass safely.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
6.7 tow rig
kentucky
Posted: 03/19/14 09:47am Link  |  Quote  |  Print  |  Notify Moderator
If you are driving so slow that you feel you need a sticker you are putting yourself and others at risk on the highways. Thats why there are minimum speed limits. Besides, if someone cant see you're RV going down the road they have other problems
2012 Dodge Ram 2500 Cummins H.O 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
pianotuna
Regina, SK, Canada
Posted: 03/19/14 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Only once in my life have I been on a highway that had a minimum speed limit. It was lower than the speed I normally drive.
I did find a regulation for Ontario -- if the vehicle is capable of traveling faster than 40 kph (25 mph) it is illegal to have the sticker displayed.
notruffinit
Minnesota
Posted: 03/19/14 09:59am Link  |  Quote  |  Print  |  Notify Moderator
These are for vehicles that cannot travel more than 25 MPH
'11 Ram 3500 Cummins
'12 Cameo 34SB3
popeyemth
owensboro ky
Posted: 03/19/14 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Here's my sign [emoticon]
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
dalenoel
S.E. Michigan
Posted: 03/19/14 10:09am Link  |  Quote  |  Print  |  Notify Moderator
The Michigan interstates have a minimum of 45 mph.
03 Monaco 36PBD DP
08 Jayco Eagle 322FKS (SOLD)
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Tracking campgrounds with Ultimate Campground Log
DougE
New Braunfels, Texas USA
Posted: 03/19/14 10:40am Link  |  Quote  |  Print  |  Notify Moderator
As I travel at 65 mph or less and have some interstate highway to travel with an 85 mph speed limit I have been considering adding a couple of small amber LED flashers on the back of the trailer. Is this a workable solution?
2005 Leisure Sprinter Class B/2015 Honda CTX700
Page of 9
