Woodalls Open Roads Forum: General RVing Issues: Electrical Shock!!
 > Electrical Shock!!
littlemo
AR
Posted: 04/20/14 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Today I was working around my MH. I had a basin of water and was cleaning out my outdoor storage compartments. Of course my hands were wet as I was cleaning and I kept feeling a pinch when I grazed against the frame of compartment. This happened several times and not at the same place. So I guess my entire MH was "shocking". It was plugged into my usual area that we have in back yard with no visible breaks in cord or anything unusual about the receptacle. Any ideas? This had happened once before when we were at a campground and it was raining heavily and we kept getting small shocks when we went in the door. Thanks for any input!
donn0128
Pronounced Ore-gun
Posted: 04/20/14 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Bad ground. Are you using an adapter? Very common for cheap ones to fail.
The Other Dallas
Over 1,200 volunteer hours
pugslyyy
North Carolina
Posted: 04/20/14 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah definitely a bad (or floating) ground. Get it checked - and don't pee on the side of your MH! [emoticon]
TucsonJim
Tucson, AZ, USA
Posted: 04/20/14 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Get to the bottom of this, or somebody may receive a very serious shock one of these days.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
time2roll
Posted: 04/20/14 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Have you plugged into a GFI protected circuit lately?
Otherwise start with an outlet tester to check the supply outlet and the outlets in your RV.
2001 F150 SuperCrew
675 watts solar
diazr2
Oregon
Posted: 04/20/14 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Its always the ground. Check the ground then when you finish checking the ground check the ground again..
FlatBroke
CO/AZ
Posted: 04/21/14 02:54am Link  |  Quote  |  Print  |  Notify Moderator
I had a band extension cord that I was using cause that. Couldn't see a thing wrong with it.
Hitch Hiker
"08" 29.5 FKTG LS
ChooChooMan74
Tiverton, RI
Posted: 04/21/14 03:26am Link  |  Quote  |  Print  |  Notify Moderator
Are you also using a surge/voltage protector?
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
nomad297
Alexandria, Virginia
Posted: 04/21/14 03:42am Link  |  Quote  |  Print  |  Notify Moderator
RV Hot Skin Condition
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
RoyB
King George, VA
Posted: 04/21/14 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that RVs get their frame ground from the SHORE POWER CONNECTION. You are at the mercy of a properly wired SHORE POWER PEDESTAL or your SHORE POWER CONNECTION cable.
I most always use a KILO-A-WATT meter and a CIRCUIT TESTER at the PEDESTALS before hooking up. Just takes a minute to test.
Must always use all three conductors for the 30AMP system and the four conductors for the 50AMP systems.
Roy Ken
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
