Woodalls Open Roads Forum: General RVing Issues: Your Torque Wrench?
 > Your Torque Wrench?
Page of 7
nomad297
Alexandria, Virginia
Posted: 05/31/14 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Based on many posts here, it seems that many of you travel with a torque wrench. I have never owned or even used one, and I have turned many a nut or bolt with torque specifications just by guessing. As far as I know, that method has worked, but for some reason now, I feel that I should be torquing things properly -- paranoia, maybe? Owning a travel trailer, I have many nuts and bolts with torque specifications that require frequent removal and replacement, so I think it's time for me to buy a torque wrench.
What brand and model torque wrench do you use? Are there any accessories that go along with it for various applications?
Thank you,
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
gbopp
The Keystone State
Posted: 05/31/14 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Torque Wrench Posts
nomad297
Posted: 05/31/14 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Being the idiot I am, I didn't even think to do a search. There is a lot of information here about torque wrenches, but not many posts stating the preferred make and model.
Bruce
sch911
Rochester Hills, MI
Posted: 05/31/14 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I have the Craftsman 1/2 drive Micro Click torque wrench.
Also, a couple of 1/2 drive extensions, and a full set of 1/2 drive sockets metric and US. This is just a small subset of what I carry in the Motorhome at all times.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2007 Jeep Grand Cherokee Limited Toad
Dog Folks
Naples, Fl. USA
Posted: 05/31/14 06:24am Link  |  Quote  |  Print  |  Notify Moderator
X2. It has served us well for 8 years now.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 05/31/14 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Dog Folks wrote:
X3 had mine 11 years now.
Eric
2014 Enterra 314RES (Cruiser RV) TT, Equal-i-zer 12K, Honda 2000 Genny
2014 Ram 1500 Quad Short Bed, 5.7L Hemi, 8 speed auto, 4x4, Line-X
FQCC/Camping Quebec, KOA, Good Sam
BuckBarker
Treasure Coast Florida
Posted: 05/31/14 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget that adding an extension onto the wrench so the socket will reach the lug nuts will change the torque reading. These wrenches are calibrated with a socket mounted directly onto the wrench.
nomad297
Posted: 05/31/14 06:39am Link  |  Quote  |  Print  |  Notify Moderator
This is true, so how do you adjust for this, or do you just apply as much pressure as possible towards the centerline of the socket and hope for the best?
Bruce
gbopp
The Keystone State
Posted: 05/31/14 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Bruce
You will get a lot of opinions on preferred wrenches.
Here is an article, I think it's a couple years old, from Car Craft Magazine on Torque Wrench Testing.
Let us know what you decide to buy. I don't own a torque wrench so, I can't give you my opinion.
Enjoy your travels.
1492
Washington, DC
Posted: 05/31/14 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I always torque to specs. Especially if any tires were replaced or inspected using impact wrenches. Few take the effort to use torque bars.
Case in point, I recently bought new tires for my van. When I went to take the tires off to replace the hubcaps, the tire lugs wouldn't budge. They were likely torqued to around 250ft-lbs, when they should be at 95-100ft-lbs. Long story short, I ended up breaking one stem which was embedded in the lug, so had to replace the entire wheel hub. Not particularly difficult, but a pain as it was due for state safety inspection, and wouldn't have passed with one lug missing.
If you buy new tires, I'd recommend going back and re-torquing all your lugs yourself.
Page of 7
