Woodalls Open Roads Forum: General RVing Issues: How durable/reliable are slideouts?
 > How durable/reliable are slideouts?
bigfatguy
compton, ca
Posted: 07/18/14 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
As I look around at various RV's to eventually figure out what I'd like to buy, one of the designs I really like has a rear-facing slideout. With it in, the bed is a sofa, and if you slide it out the sofa becomes a bed, but if it were to break the sofa would be stuck as a sofa, and I'd have nowhere comfy to sleep.
How reliable are slide-outs? If they do fail, is it possible to manually drag the slide-out out?
I know I'm being paranoid... it's the price of being an engineer...
ronfisherman
SE Michigan
Posted: 07/19/14 04:24am Link  |  Quote  |  Print  |  Notify Moderator
Get manuals on the slide. Almost all of them have some kind of override to make them operate when the system fails.
2012 Chevy Captiva Toad
Super C Group Forum
D & M
Laurel, MD
Posted: 07/19/14 04:32am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of variables in "reliability". Who the manufacturer is. How often is it used. What materials are used in it's construction.
I have a 3 slide outs on my MH and never had a problem. They are powered, but there is a method to retract them manually. The premise is that if the unit fails you don't want to drag it out because you might not be able to get it back in and then you are stuck.
You might want to if there is a procedure for doing what you want to do in the owner's manual
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (a Boston)
Izzy, Pepper & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
My computer beat me at chess once; but it was no match for me at kickboxing.
lovemytt
Fort Worth Texas
Posted: 07/19/14 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Think safety. Ours has a manual way if the electric way fails. This is our first slide and have had the same concern. Now i wouldn't have a trailer without one. Extending the width of the trailer is very nice.
2006 Dodge Ram Mega Cab Hemi Engine
2012 R-Vision Crossover 200
Fizz
Ottawa, Canada
Posted: 07/19/14 05:05am Link  |  Quote  |  Print  |  Notify Moderator
I'd be more worried about having to sleep on a sofa bed.
Most I can take is two nights.
Bumpyroad
Virginia
Posted: 07/19/14 05:08am Link  |  Quote  |  Print  |  Notify Moderator
if it is a sofa bed, you will have no comfy place to sleep, even before it breaks. both of my slides worked fine for 14 years.
bumpy
valhalla360
No paticular place.
Posted: 07/19/14 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Ours is 17yrs old and while I've never used it, there is a hole for a hand crank (now where the hand crank is...)
Tammy Mike & the Bilge Rat (AKA: Diego)
Ford F250 7.3L
1997 Sunnybrook 27' 5er
1995 Gemini Sail Catamaran 34'
Full Time spliting time between boat and 5er
scbwr
North Ridgeville, OH
Posted: 07/19/14 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Our 2002 Sunline TT had a slide and it only gave me a problem once. I couldn't get it to go in or out, so I started looking and discovered a ground wire under the slide had come out or broken off. Once the wire was back in the ground connection and tightened, everything worked fine. We just traded in that trailer a year ago after ten years of service.
Our Winnie has one of the newer Lippert slide systems, which is working fine so far. I've read about some problems with them, but it seems many problems in earlier years were due to poor installation of the 4 tracks that are used.
We like having a slideout, especially for the room it creates in our smaller trailer. I would just check it out carefully before signing on the dotted line and make sure it works properly.
Ditto on making sure you have the instructions on doing a manual override.
2007 Toyota Tundra 5.7
2014 Winnebago Winnie 2201DS
Equalizer hitch
Celebrating our 27th year of camping!">
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
downtheroad
Pacific Northwest
Posted: 07/19/14 07:51am Link  |  Quote  |  Print  |  Notify Moderator
3 trailers with slides over the years. Never had even one not come in or go out every time we pushed the button. Never had one leak either.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
johnnyrv
florida
Posted: 07/19/14 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Leaky slides that dont retract are a very common complaint.
