Woodalls Open Roads Forum: Black & Grey tank chemicals - What do you use ?
 > Black & Grey tank chemicals - What do you use ?
Dakota98
Idaho
Posted: 08/25/14 06:31am Link  |  Quote  |  Print  |  Notify Moderator
I'm using Calgon & deorderizer in the black tank now. What else can I do ?
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
Golden_HVAC
Fulltime, CA, USA
Posted: 08/25/14 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Go to CampingWorld.com and check out the black water chemicals. They will neuteralise the smells.
I use something with "Orange" in the name. It smells like oranges, and controls the odors well.
I have no idea what Calgon will do to the tanks, and probably nothing to control odors.
I do not treat my grey tank, unless in summer it gets hot and the water starts to smell a bit. Then a ounce of black water treatment will kill off some of the odor causing bacteria. Usually it is not needed below about 95F, or when in full hookup campgrounds (when the back tank valve is kept closed and grey tank valve kept open).
Also worthy to mention is keep the black tank valve closed until the tank is around 1/2 full, then drain. Otherwise the solids can build up in the tank, while the little liquid drains past it. Fill with water to around 3/4 full before draining, so that all the solids will come out of the tank quickly with all that water.
Fred.
mbrooking
Tyler, Texas
Posted: 08/25/14 06:41am Link  |  Quote  |  Print  |  Notify Moderator
We use Oxy-Kem found at Walmart. Easy to use, just drop a pack in the toilet and add a tankful of water.
2010 Winnebago Journey 40L
Dick_B
Palos Heights, IL USA
Posted: 08/25/14 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Valterra's Pure Power Blue (1 pouch), a cap of Calgon liquid and a few squirts of Dawn liquid dish soap and a toiletfill of water added after each dump.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Dakota98
Idaho
Posted: 08/25/14 06:57am Link  |  Quote  |  Print  |  Notify Moderator
OK, I currently treat the black tank with Walex Porta-Pak "during use". Nothing in the Gray tank.
The Calgon acts as a release agent, If I understand correctly.
Should I add a "cleaning agent" to the Grey tank ? If so, what ?
I've heard that both tanks, after dumpimg, should have a little water put back in them along with chemicals to keep the seals damp & help clean both tanks
* This post was edited 08/25/14 07:09am by Dakota98 *
MNRon
Fulltiming
Posted: 08/25/14 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Search on 'geo' for the black tank, never used anything in the gray.
We've been loosely using this method for many years and are happy with it. I make sure there are a few gallons of water in the black before starting any trip. Add in a capful or so of liquid calgon and same amount or so of detergent most of the time. Once in a while toss in some bleach too. More often than I might intend, forget to add any chemicals [emoticon]
Ron & Pat (and 2 Portuguese Water Dogs)
2013 Silverado 3500 Duramax SRW
2005 HitchHiker DA 31.5LKTG
rk911
Wheaton IL
Posted: 08/25/14 07:01am Link  |  Quote  |  Print  |  Notify Moderator
RV Trine after each black tank dump and the same every now and then in the gray.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
dbbls
Missouri
Posted: 08/25/14 07:07am Link  |  Quote  |  Print  |  Notify Moderator
I use H2O. Lots of it and my tanks never have any order.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
K Charles
Connecticut
Posted: 08/25/14 07:20am Link  |  Quote  |  Print  |  Notify Moderator
We use only water.
rockhillmanor
On the Road
Posted: 08/25/14 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Answers will vary depending on HOW you RV. Once a month? Every weekend? Snowbird, Full timer, etc. How much you use your coach and in what type of weather you RV in does make a difference on what you will use.
I use Campa-Chem (powerful odor control one NOT the green one)
This product actually breaks down waste and controls odors it is not just perfume. I tried some of the new ones and it added so much perfume to the coach I had to pull off the road and dump and flush it.
This product has been around for eons for marine and RV holding tanks. And walmart carries it. So when you stop for groceries etc you know you can pick up your rv holding tank supplies.
Gray tank gets a quart of a dollar orange cleaner every other dump.
