Woodalls Open Roads Forum: Class C Motorhomes: Brakes 1989 GMC Vandura
 > Brakes 1989 GMC Vandura
bcjet
Burlington Ky
Posted: 08/18/02 04:31pm Link  |  Print  |  Notify Moderator
I have a 1989 Coachmen Catalina on a GMC 3500 Vandura Chassis. I have one or both brake calibers slightly rubbing after they heat up. The hotter they get the louder the rubbing or clanging sound gets with the brake released. I don't think the rotors are warped because you don't feel any pulsing when you push on the brake. It seems like the caliper are sticking a little. Should I rebuild the calipers or replace the master cylinder.
Thanks BCJET
Cincinnati Oh
1989 25ft Catalina
*This Message was edited on 18-Aug-02 07:03 PM by bcjet*
lamont
,va
Posted: 08/24/02 03:52pm Link  |  Print  |  Notify Moderator
I have a 86---and my problem just as you describe was---the front flex hoses from the frame to the calipers---i changed them the problem went away---hoses about 29.00 each-be careful how you bleed the sys.use only dot 3 gravity can drain/bleed the sys some into a jar-so make sure it becomes clear -get all the old stuff out-.sparky
bcjet
Burlington Ky
Posted: 08/26/02 05:54am Link  |  Print  |  Notify Moderator
Hey Thanks, I justed finshed it yesterday. I pulled the calipers off to clean and inspect the seals the seal were bad so when I went to get the seal kit I asked how much were new Calipers? I wanted GM calipers also, they were only 26 dollars so I put two new calipers on and I got a new master cylinder,the old one was pretty rusted and so muck gunk in it was easier just to replace it for 44 dollars. Changed it all in about 3 hours and for about 100 bucks. I figured it was cheaper to do this then take it to the shop. The brakes are quiet and work so much better than before.
Bcjet
25 GMC Coachmen Catalina
lamont
,va
Posted: 08/26/02 11:00am Link  |  Print  |  Notify Moderator
glad it's all fixed -hope it last's a long time -i had to put timing chain and gears last week on mine 160,930 miles-
sparky
