Woodalls Open Roads Forum: Tech Issues: Fuel filter as water filter?
 > Fuel filter as water filter?
Hi
Springfield
Posted: 08/21/03 05:18am Link  |  Print  |  Notify Moderator
Does anybody know of any reason why a fuel filter cannot be used as a water filter?
I asked this question before when somebody made a comment about it within some other thread where water "contamination" of a fuel filter was mentioned, but this forum's sofware isn't very helpful even when it comes to finding responses to one's own posts.
I would like to use fuel filters to prevent any blockages in the windshield and water injection systems but I noticed that one of them went "foggy" on one side.
* This post was edited 08/22/03 04:13am by Hi *
Larry&Linda
Palatka, Fl
Posted: 08/21/03 05:46am Link  |  Print  |  Notify Moderator
I think you meant you want to use a fuel filter as a water filter, that's what your post subject says anyway.
Fuel and water don't mix so when water gets into a fuel filter that does not have a separate "sump" (water separator)to hold the water the filter will probably quickly clog because it gets gummy or jelly like.
The only reason I can think of that could cause a problem is that the fuel filter is manufactured with the intent of having mineral products (gas/diesel) in the filter at all times and is not designed to have water in it. the materials and gaskets it is made from may react (swell, shrink, discolor, etc.) when it is used with water versus fuel.
The discoloration you are seeing is probably caused by just this sort of reaction. It may not harm the life of the filter.
Trial and error seem to me to be the answer and you are already into this, so let us know what you find.
Larry
Larry and Linda
2002 Ultrasport 3126E Cat-300
Toad - 2003 Limited Edition Jeep Liberty 4X4
Blue OX Aventa II Tow Bar
Unified Tow Brake by US Gear
FMCA #F333931
Chris Bryant
DeLand, Florida, USA
Posted: 08/21/03 06:32am Link  |  Print  |  Notify Moderator
I would think the kind of filter which has a screen in it- rather than a paper type element would work fine. I'm using one of these- a clear pyrex type body with a screen in it- to filter the return line of my power sterring system.
IIRC, I found it in the "speed" section of a chain auto parts store.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
cruizer
~ U S A ~
Posted: 08/21/03 06:34am Link  |  Print  |  Notify Moderator
Why would you want to use a fuel filter as a water filter - the water from
a fuel filter would have contaminates and chemicals from the non-food or
non-potable water grade components .
Water filters are about the same price as fuel filters .
If you think knowledge is expensive , think about the price of ignorance .......
Hi
Springfield
Posted: 08/22/03 04:25am Link  |  Print  |  Notify Moderator
non-potable water grade componentsWater filters are about the same price as fuel filters<
Where do you find $1.50 water filters with windshield water pump size hose attachments and as easily available as fuel filters?
DJinCO
Colorado
Posted: 08/22/03 08:12am Link  |  Print  |  Notify Moderator
Just a thought, but the fuel filter, even brand new and clean, will not provide the same level of filtering as a water filter. I would think that the water might taste "odd" also after going through that fuel filter.
Come on Tony, don't be so cheap. Spend the $10 on a water filter. How much did you spend on your RV? And fuel!!!
Cheers,
Cheers, Doug
2001 Tahoe (5.3L; 3.73 rear; Mobil 1 fluids; BFG T/A AT)
Wester's Garage Custom Tune
Ranch Hand Bull Nose bumpers (F&R) w/ LightForce 170mm Lights on front
Air Lift air bags in the coils
Putnam Class V Hitch
2001 Prowler 27H
Hensley Arrow
NGRRFan
Colo. Spgs., CO
Posted: 08/22/03 09:18am Link  |  Print  |  Notify Moderator
If you read what he's talking about, he's not wanting to filter his water supply, he wants to use the filter in the water injection system and for the windshield washer system.
Personally, I've never encountered any contaminants that would clog either of those systems. I don't see the need for a filter.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
DJinCO
Colorado
Posted: 08/22/03 09:21am Link  |  Print  |  Notify Moderator
Oh. OK. Nevermind.
Cheers,
Andromeda451
Phoenix, AZ, USA
Posted: 08/22/03 11:40am Link  |  Print  |  Notify Moderator
Most fuel filters are designed to block water(larger molecules) and allow fuel passage to protect the carb/fuel injection.
BG
Andromeda
1984 30' Pathfinder P30 454
1973 type 181 (toad) aka THING
doogdoog
Honolulu, Hi USA
Posted: 08/22/03 01:23pm Link  |  Print  |  Notify Moderator
Aloha,
If all you want to do is filter the small stuff for the windshield
washer and water injector, just get your wife's panty hose or similar and cut off a small piece and wrap it around the water inlet of the hose and leave it baggy so you have more surface area exposed. Usually there's a small screen filter plugged in on the end and if it doesn't, you can get one at the auto parts store. If you go the panty hose route,
don't put it back in her drawer with the hole in it.
Mahalo,
Howard
