lm17
NJ
Ok I de-winterized today. I noticed my water pump is acting funny. when i turn the water on the pump goes on-good. if i turn the water real low the pump cycles on and off real quick kinda like stuttering. Isnt it suppose to cycle on then off then on again when pressure drops to low. any ideas.
2000 Dodge 2500 QC 4X4 Cummins Long bed
2003: 40' Dutch Park Model park home.
2001: S&S 9.5SC Ponderosa Truck Camper
CampingNut
CPC
San Fernando Valley, USA
I think that if you leave the faucet on the pressure does not get a chance to build up and shut the pump off. Also, you may have air in the lines. Open all the faucets (pump on) and let run for a few seconds and then shut the faucet closest to the pump off first and then work out to the last faucet on the line. Hope this helps.
local temperature
Our Pics.
cougar28
Lowell,AR USA
Sounds like you still have air in lines.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing 2002 278EFS Keystone Cougar,Handy 5er tailgate
lm17
NJ
You may be right about the air. I'll finish up tomorrow and give it a try. Thanks so much.
CJ&T
Houston, Texas
You might want to check the inline cartridge filter (if your setup has one). My pump was doing exactly as you described, and it turned out to be a plugged filter. Even though the filter looked clean, it was restricting the flow too much. Couldn't hurt to check !
1991 GMC Sierra Ext Cab, 350 V8, 3.42
2001 Rockwood T2605
Prodigy Brake Controller
Wilma&Jim
N.E., Ohio
We had to replace our filter on our old Terry Resort also. It didn't look bad but it took care of the problem.
Jim
Wilma and Jim
2002 F350 Island Blue/Lariat CC/2WD/SRW/LB/V-10/4:30/Prodigy/Reese Dual Cam with 1700# HP Trunnion WD bars/A.R.E. CX Series Topper with Walk In Door, carpeted and a Bed Rug.
Towing a 2003 Cedar Creek 36RLBS TT. 61' Bumper to Bumper
H John
Littlestown, PA
The pump action sounds like my trailer before I put an accumlator in line. It is a small air bag in a cylinder. It applies additional pressure to to water allowing the pump to run for a half a minute or minute building up pressure and then shutting off.
My reason for commenting on the accumlator is as follows. If you have one in your trailer and did not know it, it may have lost pressure causing the pump to act as if it is not there. I suggest you follow your lines from the pump and see if the bottle is in line. It should be close to the pump. If you do not have one then what you describe for a dribble is normal and an accumlator will fix it. I found it in the rv catalogs. It was a simple installation.
Good luck.
John and Ann
2003 Dodge Ram 3500 Diesel HO, Quad cab,
long bed, 6 speed, 3.73 rear end, 4x4,
Jacobs exhaust brake and Banks power.
2007 Montana 3295 5th wheel
Jordan brake controller
Ham Radio KO4A
