LeRoy Preston
constantine Michigan USA
Any good ideas on quieting down the water pump. Every thing works good on our M.H. except when the pump kicks on you think a train is coming by. Have check and it is mounted on a rubber base. Any ideas?
agkcpa
Santa Barbara, CA
Make sure you have at least 6" of clear flexible tubing between the pump and the plumbing system. Check the routing of your water line to see if there are any areas than can contact the RV during vibration of the line. These are simple and inexpensive things to do. If that doesn't work, consider adding an accumulator tank. That will really quiet things down.
Happy Travels,
Art
Come Visit Us At RV Lifestyle
wolfe10
LeRoy,
Most of the noise is transmitted to the interior by the use of hard/rigid plastic pipe going directly into the fresh water pump. If yours is hard plumbed, slightly remounting the pump so you can install about 3' of "flexible reinforced PVC for potable water hose" avaliable at most hardware stores on the inlet and outlet side, you will eliminate about 1/2 of the noise. If a Shruflo, they have the pump to hose barb fittings available in straight and 90 degrees. I have made this modification on several RV's and boats. Your total cost of parts will be under $12.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
bullyus
calgary alberta
just finished adding 16 inches of flexable to to both sides of my pump. also added shurflo accumulater tank and mounted everthing on a 2inch piece of medium foam.. this worked great!! pump is now very quiet and no more rapid cycling.
LAdams
Northern Illinois
You can do all of the above and/or you can change the pump to one of the new linear models such as the Flo Jet VSD or SureFlo 5.7... These pumps are REALLY quiet... I can't even hear my FLo Jet run under most conditions...
You can also try a pump noise isolation mount... My Flo Jet is mounted to one in addition to soft entry/exit lines and foam insulation around rigid water lines...
Here is the article for the PUMP NOISE ISOLATION MOUNT...
Best Regards,
Les
*This Message was edited on 23-Apr-03 12:53 PM by LAdams*
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Delta 6
Oxnard, Calif
Just addressed this issue with my pump. I used some insulating pipe material used to wrap around small diameter pipe. Used it for the pipe section that goes through a wood joist and also packed some around the pump where it is mounted to the bulk head. Cut noise level in 1/2 to an acceptable level.
2003 Nu-WA HHII 32.5 UKTG, 2004.5 Dodge 3500 SRW Quad cab SLT, auto, long bed, 4.10s, Reese 16K,
MaineRoger
Livermore, Maine, USA
Recommend starting with the "kiss" principle. Probably all the information you have received is good but I would start by making sure the tubing is tied down and is not loose and able to hit a wall or pass through. Mine is noisy when the tank is nearly empty and haven't bothered to fix it; the rest of the time my new pump is almost too quiet.
Remember: Rear Drum Brake users; please do not forget to use the brakes when backing up occasionally to adjust them.
1989 Winnebago Chieftain
Chevy 454, Bilstiens
148,100 miles/115,000 of them mine.
No pets, no co-pilot.
Big Suitcase: Winnie
Little Suitcase: 1400 miles on AT in 2001.
325 miles in 2003.
