Woodalls Open Roads Forum: Fifth-Wheels: broken leaf spring
Search only in Fifth-Wheels
 > broken leaf spring
dale716
Tecumseh, Oklahoma
Posted: 07/03/03 05:30am Link  |  Print  |  Notify Moderator
I have a 35 foot manhattan made by travel line (no longer in business) and on a return trip from Texas last week I pulled into a mall parking lot to get the grandaughter breakfast. When we came out I noticed something hanging down behind the back trailer tire. I looked underneath and found that the rear leaf spring was broken at the bolt hole that holds the leafs together. (It must have happened when I pulled into the parking lot)
I called Good Sam roadside service and got the name of a shop that could fix it (in Tyler Tx). The shop was about a mile away and I thought I could limp to it.
About three blocks down the road a lady pulled me over and I found that the rear axel was moved severly to the aft of the mount location. I called Good Sam again and they sent two wreckers to help me. THe drivers chained up the back axel and I was able to get to the shop.
I had all four springs replaced with heavy duty for $270.00 including labor. I think that was a real bargan.
The point of the story is: Check your springs. Mine had an old crack half way through the bolt hole that I might have noticed if I had looked before the trip. If that spring had broken at highway speed I think I might have been pulling a sled with no wheels.
Alumaliter
Northern Virginia
Posted: 07/03/03 10:10am Link  |  Print  |  Notify Moderator
I had the same thing happen on my old Alumalite. I determined that it was beacuse I stored the trailer on a very unlevel parking surface and had to crank the landing gear up a great deal to level it. After I corrected the storage issue the problem went away.
Moral of the story, don't store a trailer out of level for long periods of time. Excessive weight on just one axle causes spring to break.
Enjoy,
Bill
'02 Mallard 24 5M
'04 F-250SD XLT,V-10,4X4,3.73LS,
Lightningjack
Florida
Posted: 07/04/03 04:30pm Link  |  Print  |  Notify Moderator
Dale, thanks for the warning. I have read in the forums where the bolt hole may elongate so that might also be a precursor to failure. It's one thing I always check each day while traveling. Good post.
